Old 10-21-2002, 08:43 AM   #1 (permalink)
01 after Cam swap
I had a cam swap done by Morgan Motor Sports and here's the results.
415 rwhp and 385 torque
I already had pretty much all the bolt ons you could have plus
I had an underdrive pulley added at the same time.
The car sounds mean!
The drivability is close to the same with a couple of issues.
The car seems to surge a little at even speeds on the highway and it doesn't always hold an idle. I'm sure these issues will be worked through.
Now I just need to get it to the track to see the real differance!
2Charmed
1967 427 Marina Blue/Blk Rdstr.
1968 427/435 "ZL-1 Stripe Mule"
2001 MY/BLK Z06 "Modded" H/C, Headers, prgmg, lowered, etc
2004 BLK/BLK Z06
2charmed is offline   Reply With Quote
Old 10-21-2002, 08:45 AM   #2 (permalink)
Send a message via ICQ to NetJunkie
Woooo.... Which cam? How is the idle?
'02 Nissan Xterra SE/SC.
NetJunkie is offline   Reply With Quote
Old 10-21-2002, 08:48 AM   #3 (permalink)
Net Junkie,
the specs on the cam are 229 .578 114
At Idle, the car sounds like a race car. I have had several people comment on how good it sounds. I'm sure my nieghbors won't like it much though
2Charmed
Old 10-21-2002, 10:37 AM   #4 (permalink)
SCS
Are you still running stock heads???
If so damn good numbers.
Good Luck
SCS
SCS is offline   Reply With Quote
Old 10-21-2002, 10:43 AM   #5 (permalink)
Who made the cam? What other mods do you have? Any tuning?
Old 10-21-2002, 10:54 AM   #6 (permalink)
The heads are stock with valve spring upgrades and titanium
valve stems and hi tech push rods.
The cam is a custom grind cam and the other mods are as follows:
HallTech Tric
HallTech Ported Throttle body
Throttle body by pass
B&B Shorty Headers
Dual Bassani X-Pipes (Catless)
Borla Stingers
Dyno Tuned
Custom Programming
Ripper Shifter
Lowered
Vincie Fan Controller
Brey Krauss Harness Bar
Team Tech Harnesses
2Charmed
Old 10-21-2002, 01:51 PM   #7 (permalink)
SCS
I still say "damn good numbers for stock heads"!!
Good Luck and enjoy
SCS
Old 10-22-2002, 03:15 AM   #8 (permalink)
Flying Ace
Very interesting numbers. Was removing the cats mandatory?
Old 10-22-2002, 03:31 AM   #9 (permalink)
Banned
Send a message via AIM to kumar75150
sweet numbers...very similar to mine
kumar75150 is offline   Reply With Quote
Old 10-22-2002, 06:51 AM   #10 (permalink)
Gottta get prety rad on the cam to have to change heads for any SIGNIFICANT gains............
They flow very well stock.......
Old 10-22-2002, 07:08 AM   #11 (permalink)
Nice numbers. I do believe I am gonna have MMS add H/C to mine soon. They did my S/C. Don't worry about the little things. They will fix them. I must admit, MMS is very good about the follow up stuff, and they seem really concerned about making the car "right" for the individual driver. THere were a couple small issues after I had the work done on my car, but they fixed them right away. And by the way, Derek, who is part owner of the shop, is an awesome mechanic. Nice guy too. He never seems to get much credit, but he's the one that really gets his hands dirty there.
AWSM_06 is offline   Reply With Quote
Old 10-22-2002, 02:59 PM   #12 (permalink)
Removing the Cats was not mandatory, the options are running
stock cats, running long tube headers and removing the pre-cats,
running hi flow cats or removing them all together.
Kamu,
Do you have long tube headers? I'm wondering if the differance in your numbers from mine are the headers, the cam is slightly differant, or your car is simply stronger? My car has 3400 miles on it, so there may still be some power has it loosens up?
I'm thinking of going to Long Tube headers and then who knows from there? Maybe a blower
Regards,
2Charmed
Old 10-22-2002, 05:24 PM   #13 (permalink)
Banned
With a cam already there, you should pick up at least 15 horsepower with headers. You might need to get the car tuned again though.
Old 10-22-2002, 05:27 PM   #14 (permalink)
Thanks Kumar,
I do have B&B shorty headers, but I think I'd pick up another
10 to 15 hp with Long Tubes.
2Charmed
Old 10-22-2002, 10:18 PM   #15 (permalink)
Originally posted by 2charmed
Net Junkie,
2Charmed
Is that a single pattern cam? How high are you reving it? Any chance you could post your dynographs?
Cameron
2002 Corvette Z06, Torch Red/Blk
Sold- June 2005
ZO6Cam is offline   Reply With Quote
3/7 cylinder swap cam MilleniumZ06 C5 Z06 - Pit Road 4 05-23-2006 08:35 AM
Heads and Cam Swap AlanC C5 Z06 - Pit Road 3 06-07-2005 06:25 AM
Where should I go? (Cam Swap) easvette C5 Z06 - Pit Road 5 03-08-2005 12:22 PM
What did pay for your cam swap??? Gman2002Z06 C5 Z06 - Pit Road 16 09-24-2004 05:35 PM
cam swap rickeycatzzzzzz C5 Z06 - Pit Road 6 12-09-2003 05:53 AM
