Doc,
Thanks, was hopping there would be some kind of sway bar improvement.
I installed my Penske DA which i do not know why i rushed and bought them from a local Penske dealer and the valving seems to be on the soft side, the rebound i started with at 1 1/2 which is 9 turns was to soft and i would bounce over bumps, i change it to 3 turns and it is tighter and will be going to the track this weekend.
Compression was a little soft as well i think i will have to re valve them.
Did you get dyno spec sheets with your shocks.
