Old 10-31-2003, 03:29 PM   #1 (permalink)
Send a message via AIM to GODUCKS
100% Stock '03 Z06 Dyno Numbers
My car is 100% stock of the show room floor, 2000mi on the motor.
Dynoed at Auto Repair Specialites in Gresham, Oregon.
Best #-
343.0 rwhp
334.8 rwtq
On the third pull a put a old K&N filter out of my camaro in, and the car dropped 30hp!!! I guess the filter must of been clogged, man that must of been hurting performace on my H/C camaro!!!
So how do these numbers stack up against 100% bone stock Z06's???
Thanks
03' Torch Red Z06
63' Impala SS 6.0l LQ4
GODUCKS is offline   Reply With Quote
Old 10-31-2003, 03:46 PM   #2 (permalink)
Those #'s look good. I dyno'd my 03 when it had 1200miles and I pulled 344HP & 336TQ.
Turbine-Man is offline   Reply With Quote
Old 10-31-2003, 03:53 PM   #3 (permalink)
The range for a bone stock 2002/2003 with less than 5K miles is 340 - 355, with most coming in right around 350. Correction factors, dyno to dyno variance, and how close you are to that 5K mileage mark makes up for the differences.
Les
Best #-
343.0 rwhp
334.8 rwtq
Thanks
[sold] 02 QS Z06 383 c.i.
Old 10-31-2003, 03:57 PM   #4 (permalink)
Send a message via AIM to WayneE
Les
There is a thread out there that is a poll showing stock numbers.
I know of a handful of '03 owners that have dynoed 360+rw stock. My 2003 with around 5000 miles laid down 363 to the wheels (dyno graph).
The range for the '02/'03s seem to be 340-365rw.
Camaro - Cayenne GTS - Corvette - Hayabusa - 650i 'vert
WayneE is offline   Reply With Quote
Old 10-31-2003, 06:00 PM   #5 (permalink)
Might not be a clogged filter....until the PCM catches up to the increased air, you would likely be running a little lean.
HeadHunter is offline   Reply With Quote
Old 10-31-2003, 06:03 PM   #6 (permalink)
30rwhp seemed outrages to me!! Whatever it is, I'm glad I figured it out on the dyno and not on the track or street!
Old 11-01-2003, 05:40 AM   #7 (permalink)
I think the only way to compare dyno numbers is between the cars that dyno at that shop only. Mine dynoed at 354 to the wheels and the range at that shop was as low as 335 to a high 354. I've noticed that a lot of 360+ hp cars come from dyno shops that produce numbers in that range regularly for Z06's, I think it's just incosistentcy between dynos. The numbers are basically meaningless anyway for stock Vettes. Take a sample of about 20 Z06's and have the same experienced driver run each one at the track and I bet they all run very close times, no matter what the dyno numbers are. It's all DRIVER. I go to the track every week with my other car and regularly see Z06's beat Vipers just because the Vette driver was better. There's a lot of really good 'Vette drivers out there that can drive around bigger hp cars.
69redmach1 is offline   Reply With Quote
Old 11-01-2003, 08:56 AM   #8 (permalink)
Mine was 356 rwhp 348 rwtq with about 2K miles and just a Vararam. I wish now that I would've gotten a baseline before I installed the Vararam to see if there was any difference. You're definitely in the ballpark and there could be a variance in dyno's.
Bob
Old 11-02-2003, 01:16 AM   #9 (permalink)
Send a message via Yahoo to tait_gt2002
Mine is a totally different beast, but pulling the filter (stock paper) on my car resulted in a 65 rwhp/45 rwtq loss on the dyno. Curious creatures these EFI cars are! :o:
'00 TR/BLK coupe, Z51, MN6, etc. *sold*
tait_gt2002 is offline   Reply With Quote
Old 11-02-2003, 01:18 AM   #10 (permalink)
Banned
Send a message via AIM to kumar75150
Depends on the dyno but IMO thats a little low for an 03. I have been seeing a lot more in the 360 range.
kumar75150 is offline   Reply With Quote
Old 11-02-2003, 01:58 AM   #11 (permalink)
:( Seems on the low side of the average spread for the 405 hp. 2002 & up models.
Good 385 hp. 01 Z'sss were dynoing from 338 to 346 hp. bone stock.
:o: Damn Dyno's do vary due to weather, operator, and probably normal scatter ie. standard distribution curve on test equipment and car... ie. oil & water temp. tune, humidity.
trumperZ06 is offline   Reply With Quote
Old 11-03-2003, 12:12 PM   #12 (permalink)
More air makes PCM want to run rich and loses hp, Weird but TRUE
Do a search and you will find MANY threads on this subject
22655TD is offline   Reply With Quote
Old 11-03-2003, 03:12 PM   #13 (permalink)
Right.. That's what happened when I installed the Vararam. It was actually running rich, not lean.
Bob
Old 11-05-2003, 10:01 AM   #14 (permalink)
YES, I started it. Thanks to everyone who has responded (well over 150 members) with '02 and up Z06s.
This is clearly indicated from the same poll. The "mean" from the distribution of all Zs in the survey is actually just a tad over "355" rwhp. This, of course, is for the *405HP* Z06, model years '02 to present.
Old 11-05-2003, 10:21 AM   #15 (permalink)
I have seen many,many Vette's and Z06's dynoed......This is all on the same dyno with the same operator......I have seen Z06's 02's and up vary from as low as 330 ish to 351 bone stock
2006 Victory Red Z06
490 rwhp 465 rwtq
GaryZ06 is offline   Reply With Quote
Baseline Dyno Numbers. Bone Stock 01 Z06 Brian@ICS C5 Z06 - Pit Road 9 12-19-2004 01:43 PM
Halltech Stinger - Dyno numbers before and after stock 2004 Z06 Slythetove C5 Z06 - Pit Road 6 05-17-2004 10:47 AM
First dyno today, 100% stock EB_Z C5 Z06 - Pit Road 15 07-31-2002 03:26 PM
100 Shot NOS Dyno Numbers OpticZ06 Racing 2 12-21-2001 01:58 PM
2002 Z06 Dyno Numbers: Stock .vs Halltech SideWinder Halltech C5 Z06 - Grandstand 28 08-28-2001 11:33 PM
» Latest Auto News
» New Car Reviews
2011 Kia Sorento: First Drive
2010 GMC Terrain SLT-2 Review
