572 cubic inch/ 620 hp - Z06Vette.com - Corvette Z06 Forum
post #1 of 23 (permalink) Old 11-09-2003, 08:17 AM Thread Starter
zoraduntov's Avatar
im thinking about dropping this into a 69 vert
does anyone have any comments /advice
will i need a new tranny
what else will i need to hold 620 hp down on a 69 vette
2009 ZO6 JSB/EBONY
2004 Zo6 / Z16
zoraduntov is offline
post #2 of 23 (permalink) Old 11-09-2003, 08:18 AM Thread Starter
zoraduntov's Avatar
because when will chevy put 620 hp into a RPO vette?
i say never
post #3 of 23 (permalink) Old 11-09-2003, 09:56 AM
I say go for it! I forget what tranny an L-88 came with (think it's a Muncie M22 rock crusher) but I would go with that or, if's an auto, a turbo 400. I believe that 572 CI engine is a tall block so you will probably need to go with a new hood. Just guessing though.
Racer Z is offline
post #4 of 23 (permalink) Old 11-09-2003, 10:13 AM
the block is only .400" taller.probably won't cause you any problems.
gasboy is offline
post #5 of 23 (permalink) Old 11-09-2003, 08:05 PM
Z06 Power Adder Authority
.400" taller will cause interference with the brake booster and more...even if you run the low-profile valve covers... but you wouldn't want to run stamped steel rockers on that motor, and typical roller rockers require tall(er) valve covers.
Also, if you're doing a trans swap, why stick with a 4-speed Muncie...even the M22. Those have relatively crappy gear spacing. Might as well get a 5-speed. I have a Richmond 5-speed in mine and it holds with no issues. Mine is a lot tamer than this engine (mine is ~520hp flywheel).
If you want to run a super sticky tire on it, you will most certainly want to upgrade the entire rearend. Do a search on "Tom's Rearends" and you will find some nice stuff there.
Please check on the ability to fit this block in a C3 Vette. It has nothing to do with the height of the hood...that is the intake, and with an L88 hood (I put one on my car) you will have a lot of different intake choices. But the tall deck BBCs will typically NOT fit in a Vette.
But even if it doesn't... you can easily get a 502 shortblock, add some aftermarket heads, headers, decent cam (I like hydraulic rollers b/c of ease of maintenance) and you can make 600+HP easy.
'02 Z06 (654rwhp/621rwtq)...LPE/21CMC Stage 2 Twin Turbo
'05 RAM SRT-10 RC (448rwhp)
'09 Shelby GT500 'vert (578rwhp)
'04 SVT Lightning...son's ride now, but I hold the note!
'08 Denali 6.2...wife's ride
WA 2 FST is offline
post #6 of 23 (permalink) Old 11-09-2003, 10:51 PM
I'd personally go with a 502 ramjet, there's somethign to be said about fuel injection, and that ramjet makes more than enough power to keep you happy in a nice lightweight 69 vette, I love it in a 5400 lb tahoe, I could only imagine it in something a lil more than half teh weight.
STS twins.....chicks have 553/489 reasons ta dig em
okay well that was the first stage, at least the one I'll talk about..
undertaker is offline
post #7 of 23 (permalink) Old 11-09-2003, 11:50 PM
aldrichc5's Avatar
A 69 should handle it, I put in a 454 LS7 in a 77 Vette and used the 400 turbo that came in the car and put in a manual valve body. It was pushing around 550 hp and it would not stay in a straight line, but it was fun as hell to drive.
aldrichc5
02 Z06, 04 Duramax
69 Camaro (project)
14 335 10 2SS/RS Camaro (wife's ride)
aldrichc5 is offline
post #8 of 23 (permalink) Old 11-10-2003, 09:59 AM
Send a message via AIM to Ahroun
Can't you stroke a 454 to a 540ci?
How about these options:
632 ci 1300 hp
Merlin or GM CNC Pro stock block, Callies / Cola 4340 crankshaft, Venolia custom pistons, Crane / Compcams custom roller camshaft, Jesel beltdrive, Jesel shaft rocker system, Fully ported Big Chief / Brodix Pontiac cylinder, 2x4 intake manifold, Holley Dominator carburetors, dry sump oiling system, MSD cranktrigger ignition, Meziere electric water pump.
Complete dynotuned motor $34900
Add $1500 for installed 500 hp Pro Race Fogger nitrous system.
730 ci 1450 hp
Tall block, raised cam, 5,300" stroke 4340 racing crank, Venolia custom pistons, Fully ported Brodix Pontiac heads with titanium valves, Jesel beltdrive, Custom roller cam, 2x4 sheet metal manifold, Holley 1250 Dominators, Dry sump oiling system, MSD crank trigger ignition, Meziere electric waterpump.
Complete dynotuned motor $43900
add $1500 for installed 500hp Pro Race Fogger nitrous system.
762 ci 1500 hp
Donovan P/S block with 1.000" raised cam, Fully Ported Symmetrical port heads with titanium valves, special shaft rocker system, Billet crankshaft, custom pistons, Jesel beltdrive, MSD crank trigger system, Dry sump oiling system, sheet metal intake manifold, split Dominators, Billet rail valve covers, Meziere electric high flow waterpump.
Complete dynotuned motor $52500
Call for nitrous oxide option
Ahroun is offline
post #9 of 23 (permalink) Old 11-10-2003, 10:08 AM
Not unless you buy me dinner first and talk REALLY nice to me!:D
Electron Blue/Black '02 Z06 "DRIVE IT LIKE YOU STOLE IT!!"
Vortech V-2 SQ T-Trim Aftercooled Supercharger, AFR 205's, Custom Grind "Blower" Cam, SPEC Clutch, Fidanza Aluminum Flywheel, Hardened Output Shaft, 3:73 Rear Gears And A Bunch Of Other Cool Junk...
Z06 Tom is offline
post #10 of 23 (permalink) Old 11-10-2003, 06:09 PM
This is slightly off topic but my friend is redoing her Firebird and wants to put an LS1 in it, but I can't help but ask. Could she put a long block LS6 in it? I know the V8's are naturally LS1's but I'm not sure if their is enough room under the hood for the LS6.
Babweh is offline
post #11 of 23 (permalink) Old 11-10-2003, 06:58 PM
aldrichc5's Avatar
Are you taking LS6 small block or LS6 big block? :-?
aldrichc5
02 Z06, 04 Duramax
69 Camaro (project)
post #12 of 23 (permalink) Old 11-10-2003, 07:11 PM
I owned a 69 for a long time. Bought it new. Anyway, taller block might cause tight exhaust/header problems. Wider spacing of intake ports on the heads could limit you on intake choices. GM might have intakd choices available but I have not checked lately. I would do the package mentioned earlier using a standard height block with selected mods. Good Luck
:D
RICK 99 FRC, LPE C5-R 427 TT, LPE Minitubs, Boost Controller. A ZO-6 Prototype. Born: 12/3/98
725 RWHP 800 TQ
Sack Rat TT is offline
post #13 of 23 (permalink) Old 11-10-2003, 08:34 PM
good catch, Rick. I was just thinking valve cover clearance, but Rick is right on. I have large 2 1/8" primary headers on my car and it is _tight_ in there. Pushing them up and out (which is what would happen with a taller deck) would screw things up, not to mention the potential intake issue.
A Ramjet will not fit without a custom hood. L88 hood? Forget about it.
You can go insanely fast without getting this 572" crate motor. You can go faster if you want, with parts that will actually fit. :D
WA 2 FST is offline
post #14 of 23 (permalink) Old 11-10-2003, 10:54 PM
Small block.
Babweh is offline
post #15 of 23 (permalink) Old 11-11-2003, 05:39 AM
babweh
LS1, LS6 or C5R all the same external size.
z62jag is offline
471 Cubic Inch LS2 Here! mike@Rapid Vendor Sales - C5 18 01-06-2006 03:01 PM
chevy's new 572 cubic engines zoraduntov The Garage (non Vette related) 7 02-21-2003 09:33 AM
725 HP, 427 cubic-inch, Lingenfelter Wide Body C5 MARZ06 C5 Z06 - Pit Road 47 08-30-2002 06:15 PM
How does a 435 cubic inch LS6 with 600+ hp sound? Lawdogg C5 Z06 - Pit Road 8 10-21-2001 09:34 AM
409 cubic inch C5 coupe v. my head and cam Z06 Lawdogg C5 Z06 - Grandstand 5 09-06-2001 09:52 PM
