Old 08-27-2003, 07:29 AM   #1 (permalink)
Advice on lifting my car.
I've read the how to lift without pucks, but that was for a jack. Tomorrow, I'm goint to use a lift, where do I put the arms? Also, the reason I'm lifting it is so that I can lower it using the stock bolts. How far does that lower the car? I'm wondering because the directions for the front call for a 3/4 turn on the front nuts. Didn't seem like much, but the rear goes all the way until you have 2 threads remaining.
You are only as fast as you can afford to be.2000 Mag Red II Coupe
LG Pro Long Tubes, Corsa Indy Exhaust, Granatelli MAF, Donaldson Blackwing, 160 Stat, TR 55's
Still in the box: MS4, Harland Sharps, Caddy Racing Lifters, LS2 Timing Chain, GM High Volume Oil Pump, Cam Gasket Kit, A/C Tensioner and pulley
future C5 owner is offline   Reply With Quote
Old 08-27-2003, 08:53 AM   #2 (permalink)
Send a message via AIM to WayneE
You should be able to put the feet for the lift at the jacking points where the pucks go. I have not had my car on a lift, but I do jack from those points (using pucks). Be careful not to crack the body panels around those front mounts.
I lowered my car by running the fronts all the way in and the rears out to 2 threads. Total drop was 3/4". Check my website for pictures.
WayneE is offline   Reply With Quote
Need Some Second Car Advice Nazgul The Garage 19 01-12-2004 11:46 AM
Lifting front of car RyanD C5 Z06 - Pit Road 15 05-30-2003 03:10 PM
Lifting the car....with wood...(pics) proexpert C5 Z06 - Pit Road 29 05-31-2002 08:53 AM
Car to arrive on the soon! Need advice. Rapid Transit C5 Z06 - Grandstand 1 12-15-2001 10:52 AM
Lifting car - is this ok? dimer0 C5 Z06 - Pit Road 10 07-02-2001 10:35 AM
