Old 10-30-2002, 08:50 PM   #1 (permalink)
After Market Wheels
I am considering upgrading my Z06 breaks. This will require new wheels for the front. I have fond wheel prices between 1k and 5k per set. I was wondering if some has any technical information about what wheel characteristics one should use in making a reasonable selection? Yes appearance is important.
Thanks
Tom
tweetyz is offline   Reply With Quote
Old 10-31-2002, 07:36 PM   #2 (permalink)
Options are dictated by your taste and wallet!!
What brakes? what is the clearance issue? and where? F or R
Personally I like the HRE 541's but they're pricey! again taste and $$$$ lol
Doc
2006 MACHINE SILVER & TORCH RED...BONE STOCK 505 HP -WHO NEEDS MORE...LOL
2004 Machinesilver & Torch Red.. Born ??..K & N; T/R partition; Lloyds T/R Z06 mats; Euro wheel (red/blk); STOCK 405 HP Orig own
quikdoc is offline   Reply With Quote
Old 11-01-2002, 08:50 PM   #3 (permalink)
Most (with one exception that I know of) require at least an 18" wheel with the appropriate offset in order to clear larger calipers/rotors.
In addition, larger brakes do not stop your car any faster. Tires stop your car. If the stock brakes can lock-up the wheels (or cause the ABS to activate) at 20 mph they will do so at 200 mph. Larger brakes will however be able to absorb more heat. Larger calipers have greater fluid volume and larger rotors make a better heatsink. More pistons help to prevent pad taper as well.
The real secret is to get cooling air to the brakes be they stock or otherwise. The stock brakes can be improved with the addition of cooling ducts, better fluid, SS lines, SS or titanium/vented caliper pistons, and pads appropriate for the intended use (street or track) no single pad will excel at both.
I saw a Z06 with Wilwood 6 piston calipers and larger rotors and he ended up having to go to a larger master cylinder as well in order to regain adequate pedal modulation. Initially the brakes would go into ABS with the mere touch of his toe. They did fit under the stock wheels though.
Click here to see my garage.
Old 11-02-2002, 04:06 PM   #4 (permalink)
Send a message via AIM to phil385
Tom, if you ever get rid of your stock rims and or tires give me a PM, i am looking for a set.....
~Phil
02 Quicksilver Z06; LPE Custom Tranny & Diff Cooler, LPE HD Radiator w/ Oil cooler, Brey Krause Harness bar/belt mounts, Teamtech 6-point restraints (2), Andy's Partition...All work done at 21st CMC.
05 Dodge Magnum R/T; 5.7 HEMI
phil385 is offline   Reply With Quote
After Market Wheels dfunde01 The Garage 11 09-17-2003 03:26 PM
New Z06 wheels on the market... Nate @ CorvetteGarage Vendor Sales - C5 54 05-25-2003 05:58 PM
F/S After Market Z06 Wheels chy856420 Member Sales - Parts & Cars 7 01-08-2003 01:16 PM
After Market Z06 Wheels Z49 Z06 C5 Z06 - Pit Road 1 07-20-2002 08:42 AM
After market wheels..... streetlegal C5 Z06 - Grandstand 5 07-17-2001 05:55 PM
