O.K. Here's the pics..
First you need to start with a donor visor from one of the 175+ auto models that have them today. See
Homelink website for list...
Here's my donor torn apart.
Next remove the
Homelink unit... Here's a pic of the guts...
Next if the button cover is the wrong color spray with black vinyl paint..
Now it's time to get serious. You have to remove your visor, see links included in previous message for details on removal. It's a 30 second process with a flat screwdriver and a quick twist.
Once you have it out you have to rip the seam to get into the visor. See tool in pic.
Now here's my twist. Get some T splice connectors and splice into the red and white wires. This save the step of soldering the wires together and gives you a nice tight connection.
Also see that I've outlined the
Homelink unit. Use a utility knife to cut around the outline.
Once done connect the orange Homlink wire to the white wire and the black to the red. Didn't make sense to me but it's the way it works.
Insert the unit and carefully cut through for the button cover. Snap the cover into place and get ready to sew together.
Finally, be real nice to someone who sews, my wife in this case. Have them get a heavy duty needle for their sewing machine, like the kind used for denim, and some upholstery thread. If they're careful they can sew the visor back together.
At last your done and look at the garbage you can get out of your car. I got rid of three remotes and the darn stickers for the airbags.
Anyone who wants to do this won't be disappointed with the results. The only really hard part is the sewing back together.
Good luck.
Whiplash
