B&B TriFlow PRT or CORSA Extreme
Hi all,
My TI system was destroyed internally by the gases after changing to LG Pro Headers without cats and a tune. I have now a vibration over the exhaust when it gets high temperatures at WOT, the vibration is not coming from the trans, We did the test stopped and without any gear engaged and the issue persists.
I installed the high flow cats and I am just thinking in changing the exhaust system by other branded set
Corsa has recently launched their new Extreme and outside there is no much info about it. A couple of friends of mine have the PRTs and it sounds with a very deep note that I like.
Any sugestion regarding which of both system I should choose, and do you think that the vibration will dissapear with a new system, we have analyzed it and it seems coming from the TI destroyed mufflers. We checked if there is any part of the long headers and x system that were rubbing, however we did not identified any issue
thank you for your responses
