baby seat - Z06Vette.com - Corvette Z06 Forum
Old 10-23-2002, 08:47 AM   #1 (permalink)
baby seat
I can't seem to secure the baby seat really tight. I've tried contacting GM, but no response. The tether helps, but the locking mechanism on the seat belt is a piece of ......
I heard the 2003's have a different system bc of the known problems. Does anyone know of a kit for my 2001 or technique to really tighten down the baby seat?
I've tried those locking clips, but the Z06 belt system is not conducive to them.
Thanks
ZEBRA is offline   Reply With Quote
Old 10-23-2002, 09:53 AM   #2 (permalink)
I would not recommend a child seat in the Vette, but if you must, don't ever forget to disable the pass air bag.....
JC
N4C5S is offline   Reply With Quote
Old 10-23-2002, 03:08 PM   #3 (permalink)
FiveOJoe's Avatar
Not bragging here, but I am a NHTSA Child Passenger Safety Tech. (I volunteer to go to those weekend baby seat check points and install seats.)
So here you go.
1. Don't put one in a Vette unless you have no other option.
2. Disable the airbag!!!
3. Put the seat all the way back.
4. You do not need a locking clip because in has a sewn on latchplate. (It can't move)
5. After placing the CP seat and running the seat belt through the proper path, PULL THE LOWER PART OF THE SEATBELT ALL THE WAY OUT and slowly let it retract.(It will now be switched to LOCKING MODE and you will hear it ratcheting as it retracts.) This applys to all passenger positions in most cars nowadays.
6. Kneel on the CP seat or lay across it with all your weight (it's tough-it can take it) and feed some more of the lower belt into the retractor. It will be locked into place if you SWITCHED it correctly. If it's not locked, let the belt fully retract again and start over.
7. The upper belt will be through the path, but not locked, just make sure it has no slack in it.
8. Use the tether if you have one. It stops forward rotation of the CP seat in a crash.
The biggest problem at our checkpoints is most people don't know that retractors can be switched(STEP 5) so they lock in place and restrict movement of a passenger or carseat.
Hope this helps
Joe
Old 10-24-2002, 04:31 AM   #4 (permalink)
Although I have three cars I take my son in my vette all the time. Five O Joe's advice is right on the money.
Advice Number five is the step to make it secure.
Enjoy and of course drive responsibly..
Congratulations!
JB
Old 10-24-2002, 04:36 AM   #5 (permalink)
proexpert's Avatar
Now that's what this site is all about.
Old 10-24-2002, 05:55 AM   #6 (permalink)
Future Corvette lover ???
NinjaZ06 is offline   Reply With Quote
Old 10-25-2002, 02:43 AM   #7 (permalink)
Vette Doctor
c4c5specialist's Avatar
HI there,
For 03, all Corvette have the Quick latch system for child safety seats on the passenger side.
Although, I do agree with Joe here, follow his instructions, I have retrofitted 2 2003 seat frames to earlier models, without any problems.
All the best, c4c5
Old 10-25-2002, 02:49 AM   #8 (permalink)
FiveOJoe's Avatar
C4C5:
I wasn't sure if the 03 vettes were going to have the LATCH system or not. That's good to know. Thanks.
My instructions above DO NOT apply to LATCH system cars, as you do not use the seatbelts with those systems.
Joe
Old 10-25-2002, 12:35 PM   #9 (permalink)
Thanks for all the replies. I do have the belt in lock mode, but I still can't get as tight a fit as I can on my other vehicle. I put about 230lbs of weight on the Car seat and feed the belt in, but it's still not very tight. The locking mechanism doesn't have fine increments.
I think I'm going to try to retrofit a latch system.
Btw, I agree with everything said. But my 3yr. old son is as big a car freak as I am and we just do a short Sunday morning trip to church and back.
Old 10-25-2002, 12:58 PM   #10 (permalink)
Once he gets to "4 and 40", check out the Simpson booster seat.
It's :cool: and my four year old loves it!
I can't figure out how to attach the "Hans" device?:-?
Electron Blue/Black '02 Z06 "DRIVE IT LIKE YOU STOLE IT!!"
Vortech V-2 SQ T-Trim Aftercooled Supercharger, AFR 205's, Custom Grind "Blower" Cam, SPEC Clutch, Fidanza Aluminum Flywheel, Hardened Output Shaft, 3:73 Rear Gears And A Bunch Of Other Cool Junk...
Z06 Tom is offline   Reply With Quote
Old 10-25-2002, 01:24 PM   #11 (permalink)
To c4c5specialist,
Do you have the part number for that 2003 seat rails with latch?
How much are they?
Thanks!!
Old 10-25-2002, 02:54 PM   #12 (permalink)
Vette Doctor
HI Zebra,
I will have the part numbers for tomorrow afternoon, after I get out of work.
They are in my files.
Allthebest, c4c5:eek:
Old 10-25-2002, 03:34 PM   #13 (permalink)
Originally posted by c4c5specialist
HI Zebra,
Excellent. I have no choice but to take my infant in the Corvette with me occassionally, since its my daily driver. If my wife is gone/at work and I have to take the kid to daycare or pick her up, she has to go in the vette with me.
If there's anything I can do to make the seat safer for her, I'll do it in a heartbeat.
ZO6Cam is offline   Reply With Quote
Old 10-25-2002, 04:43 PM   #14 (permalink)
FiveOJoe's Avatar
I surprised to hear you say that. I went out in the garage and pulled the seatbelt "all the way out" to "switch" mine over to locking mode and it ratchets in very "fine" increments, 5 to 7 clicks per inch. Sounds like I'm spinning my 3/8 drive ratchet by hand.
(someone else please check and verify this on another Vette)
If your sure your in locking mode and you still can't get it tight, there is one other method we use.
1. Put the belt in "locking mode" and push it through the pathway.
2. Stop when the latchplate gets about 3 to 4 inches away from the latch.
3. Pull the seat back toward the open door slightly then lean on it hard with your chest or belly and "Rock" the seat toward the latch while guiding the latchplate into the latch..
4. With a little practice you can get it very tight this way.
Not getting it as tight as your other car may be because you have more "cushion" to depress in the other seat, but I have gotten CP seats very tight (hard to move side to side) in Corvettes
The new latch system (now on every seat manufactured) is great, but older seats don't have it, so you will still need to get it tight with the belts.
Hope this helps.
Joe
Old 10-26-2002, 10:35 PM   #15 (permalink)
Thanks Joe. I'm gonna try the "rocking" technique. With the seat all the way back, the belt goes in the pathway at a more severe angle. If I move the seat up one notch it helps, but I'd like to keep the seat all the way back.
06 Z06 and baby/toddler in passenger seat? kgjevre C6 Z06 - Pit Road 10 11-11-2006 06:09 PM
FS Sparco EVO seat and hardbar seat mount - $550 shipped jackmott Member Sales & Want-To-Buy - Parts & Cars 11 06-06-2006 06:12 AM
Any interest in bracket kit to mount EVO seat to manual seat track GNX Guy C5 Z06 - Grandstand 1 02-20-2004 09:49 AM
Baby Seat!?!?!?! GreggHammer Vendor Sales - C5 11 06-05-2003 07:29 PM
can you put a baby seat in the z06? jaebaby C5 Z06 - Grandstand 20 12-22-2002 01:30 AM
» Insurance
» Latest Auto News
Chrysler Calls BS: Refutes Tesla Loan Claim
Earlier today Tesla announced that it had repaid its government loan
2014 Chevrolet Spark EV Priced From $27,495
Chevrolet has announced that its 2014 Spark EV will be priced from
Ford Officially Shutting Down Australian Operations in 2016 Video
Ford Australia has confirmed that it’ll be shutting down its
» New Car Reviews
2013 BMW X3 xDrive28i Review
2014 Scion tC Review - Video
2014 Lexus IS 250 Review
From staid to sultry
2013 Buick Enclave Review
» Featured Product
