Originally Posted by speedpup
Jack the car up and check the wheel bearing by wiggling the wheel by grabing tire top and bottom. I doubt it is a bearing but it is possible. See if you feel free play. Rotate the wheel slowy and see if it feels smooth. You can remove the wheel and try it also. Check for feel play in the hub.
I agree.
I haven't heard of wheel bearings causing this type of problem, but have heard of tires doing it. I'd do the check recommended above and if it doesn't appear there is a large problem, get your tires balanced. Balancing a tire is relatively inexpensive and would rule out the easy thing before you start spending big money on new wheel bearings (they come as a unit and the rears are something like $400+ dollars each.
The rear wheel bearing is the piece to the right in this pic:
