Re: Bank Lean Question with intake only
First make sure you do not have a leak between the maf and throttle body, if all is good then do a scan and check your long term fuel trims.
Most likely with the trap they are running quite high on the positive side, 14-20. If so mutiply your entire maf table by 1.10 to start.
408 8.5:1 CR * STS TT * 273 gears It is what it is
