Old 06-08-2006, 11:30 AM   #1 (permalink)
YumaZ06's Avatar
Baseline Dyno
Had a baseline dyno run on my stock 04 Z. The only thing not stock is the GHL magnums. I don't have a method to scan the dyno printout but here is the info:
This was on a dynojet dyno.
Conditions:
6-7-06
11:32 am
Run type: RO
Run Conditions:
91.20 degrees F
28.62 in-HG
Humidity 13%
SAE: 1.05
CF:SAE Smoothing:5
1st dyno run:
Max power = 352.55
Max torque = 329.06
2nd dyno run: (same conditions)
Max power = 359.15
max torque = 330.89
Are these numbers any good? Will report back when I get it tuned and other mods done.
2004 MS/BLK
NCM#31853
YumaZ06 is online now   Reply With Quote
Old 06-08-2006, 11:54 AM   #2 (permalink)
Good Numbers IMO.
Most 02 to 04 Zee's run between 350 to 360 RWHP. You are right in the ballpark. Remember Dyno's do vary.
Old 06-08-2006, 12:00 PM   #3 (permalink)
PerforminNorman's Avatar
Good numbers there.
Come to the Z06 Fest!
Performin' Norman
Old 06-08-2006, 12:52 PM   #4 (permalink)
KCMAGS's Avatar
Tom, those numbers are weak...needs a blower.
Old 06-08-2006, 12:53 PM   #5 (permalink)
On second thought, I am going with Keith's answer.
Old 06-08-2006, 02:30 PM   #6 (permalink)
YumaZ06's Avatar
You guys just won't let up will you?????
Old 06-08-2006, 10:11 PM   #7 (permalink)
Tom,
Those are good numbers for a stock car. Now you need to put the Vararam in and get a set of headers installed and dyno it again. The headers will really pick up your torque number.
Jimbo
sig by GR8 White
Old 06-08-2006, 10:39 PM   #8 (permalink)
Hey, nice numbers. Dynos vary.
Alex
Got My Stock Baseline Dyno Today... jchayden C5 Z06 - Grandstand 7 05-26-2006 08:01 PM
Baseline dyno.. thoughts? Wits-Z C5 Z06 - Forced Induction & Nitrous 3 10-31-2005 02:55 PM
baseline dyno results Jumper The Garage 3 04-18-2005 12:42 AM
Dyno tomorrow - baseline WayneE C5 Z06 - Pit Road 4 08-21-2003 09:41 AM
Baseline dyno done - now what? MYZ06 C5 Z06 - Pit Road 5 04-03-2003 01:34 PM
