Old 03-10-2008, 03:12 PM   #1 (permalink)
screamindman's Avatar
Braille battery for Z06
I am ready to buy a Braille batteryand was wondering what the pros and cons are. Also where can I get a good dael on one?
screamindman is offline   Reply With Quote
Old 03-10-2008, 03:32 PM   #2 (permalink)
Re: Braille battery for Z06
Originally Posted by screamindman View Post
I am ready to buy a Braille battery and was wondering what the pros and cons are. Also where can I get a good deal on one?
Pros: 20 lbs lighter than stock
Cons: Cost
Mine lasted about two years before it died. I am back to stock. Mostly because I needed one right away and couldn't wait.
Old 03-10-2008, 05:41 PM   #3 (permalink)
JustinG's Avatar
Braille Battery install pic!!!
I am going to get the new 15lb CF one, for the wife's car, and when and if mine dies in the Z I will replace it with that one. Mine has been going strong for 2 1/2 yrs now. But, if I don't drive it for over a week it's on the tender.
Justin
02 TR/BLK Z06 -- V1 | Hurst/Hurst Black knob | Braille Battery | Callaway 78mm Billet Throttle Body | Callaway Honker | Elite Engineering radiator screen | Diablo Predator | Ceramic coated AR Headers
03 SGM/BLK Vert. (Wife's) -- Z06 Titanium exhaust | CF Braille Battery | Diablo Predator | Callaway Plug Wires | NGK TR5 Plugs | Shaner S2 Throttle Body
JustinG is offline   Reply With Quote
Old 03-12-2008, 06:08 AM   #4 (permalink)
racingfast's Avatar
Send a message via Yahoo to racingfast
JUSTIN--- check PM----For those of us thinking of going this way: did you use the post top with side post adapters on that? Wouldnt the B14115 work directly? Thanks!
'01 Speedway white/mod red int. RapidMotorsports 427 package, LS2 Block, 573 RWHP, 529 FT LB, 1 7/8 Kooks with no cats or mufflers, RPM Transmission & Quaife Diff, Pfadt Coil-Overs & the propeller!
racingfast is offline   Reply With Quote
Old 03-13-2008, 08:37 AM   #5 (permalink)
I just put one in the car yesterday (BC2015) ...fired right up. It will go to the track this weekend...we'll see what happens.
NA 346 CID
483 rwhp
440 rwtq
OhOneZOhSiXXX is offline   Reply With Quote
Old 03-13-2008, 11:01 AM   #6 (permalink)
OhOne...Can you PM me with a link to where you bought your Braille?? Also, what brackets/mounting hardware did you buy with it...??? Thanks....
Old 03-13-2008, 11:10 AM   #7 (permalink)
racingfast's Avatar
LeRox--- I went right to braille's site and ordered mine, along with their aluminum mounting bracket. I know some here made their own, but ya gotta look good when you go FAST!!
Their site is brailleauto dot com (not sure if they are a supporting vendor so I didnt give the entire link).
I'll put up pics when I get mine in too. I went with the B14115 eleven pounder....
Old 03-13-2008, 12:16 PM   #8 (permalink)
Yea I got mine from Braille directly too.
I have it mounted in a vented box in the center trunk for now, but will be moving it to the right corner using fabricated aluminum after this wknd.
Old 03-13-2008, 02:07 PM   #9 (permalink)
Nice. Was the aluminum bracket all you needed to mount it or do you also need the side post adapters, j-hooks, etc...???
Old 03-14-2008, 02:27 PM   #10 (permalink)
Aluminum bracket is all you need as long as it is secured. It comes with top mounts posts (the side mount option is $15 more). We haven't actually done it yet, since its still in a battery box in the center, but when we do it will likely be something we make up and nothing off the shelf. I would assume J-hooks would work.
And I took is to the track today and had ZERO problems. I am very happy with my decision.
Braille battery on the way! black96ws6 C5 Z06 - Pit Road 10 03-04-2008 10:06 PM
Braille Battery install pic!!! JustinG C5 Z06 - Pit Road 69 02-04-2008 07:52 AM
BRAILLE Batteries - Lightweight Carbon Fiber Ignition_key Member Sales - Parts & Cars 3 12-14-2007 11:44 AM
Braille Battery issues stellablu C5 Z06 - Grandstand 6 02-12-2006 08:43 AM
new battery, acid leak AGAIN.. faulty battery, or electrical problem? mannygmt2 C5 Z06 - Pit Road 9 12-01-2005 03:07 PM
