Brake Bleeding - New Rear Calipers - Z06Vette.com - Corvette Z06 Forum
Old 09-27-2009, 08:59 PM   #1 (permalink)
I just installed new rear calipers on my Z. I did not replace the front calipers. Put new pads on all 4 corners. Wanted to know if, when bleeding, I should bleed the rear corners first (since the new rear calipers are empty), or if, despite the empty rear calipers, I should follow the correct bleed sequence anyways, which is RR, LF, LR, RF for my 02' Z??? Thanks for the help....
Old 09-28-2009, 11:35 AM   #2 (permalink)
froggy47's Avatar
Re: Brake Bleeding - New Rear Calipers
hmmm,
I would do rr,lr,rf,lf
Where does that other sequence come from?
2007 BMW 328i Coupe, 2004 Z06/Z16, 1996 LT4 Coupe, 1995 BMW M3 Coupe, Ford & Chevy SUV's
2006, 2009, 2010 SCCA regional Solo champ
Old 09-28-2009, 04:21 PM   #3 (permalink)
Froggy....it comes from the shop manual. There is a specific bleed sequence for C5's (depending on the year) and its not like it is for other cars where you start furthest from the master reservoir and work towards it, like the sequence you specified. My first post is for 2002' Z's (its also good for a few other years, just cant remember which). There is a different sequence for 03's and 04's, I believe
Old 09-28-2009, 05:21 PM   #4 (permalink)
1. Follow the Shop Manual Bleed sequence.
- Make sure you tap the calipers with a rubber mallet as you bleed.
2. Do the Chevy modified Bleed technique:
- Turn the ignition ON, wait 2 minutes
- rebleed in the proper sequence
3. Drive car, testing brakes at first
- heat up brakes, using normal driving
- rebleed in the proper sequence with ignition OFF
Old 09-28-2009, 07:13 PM   #5 (permalink)
Good thing I read this because I'm about to do stainless steel lines and swap the fluid to Motul w/ speedbleeders. Does anyone have the bleed sequence for the 04 c5Z??? Thanks Jim
seamus2154 is online now   Reply With Quote
Old 09-28-2009, 10:44 PM   #6 (permalink)
seamus....looked up the bleed sequence for your 04' and its the same as my 02'. RR, LF, LR, RF.
Hey Worm, do you recommend the bleed procedure you posted with the rear calipers being new and empty of brake fluid?? Im a little concerned about doing the LF before doing the LR with the LR caliper empty, even though that is the correct sequence for my Z.
Basically, I dont want to draw an air bubble from the empty LR when doing the LF second in order. Would it be better to do the RR then LR second to get the new calipers filled, then follow the correct sequence??
Old 09-28-2009, 11:51 PM   #7 (permalink)
Last C5's Avatar
All C5 Corvettes
1997 to 2000 RR LR RF LF
2001 to 2004 RR LF LR RF
Last C5 is offline   Reply With Quote
Old 09-29-2009, 08:46 AM   #8 (permalink)
froggy47's Avatar
Cripes, that's a lot of bleeding.
Old 09-29-2009, 01:35 PM   #9 (permalink)
Thanks Lerox!
Old 09-29-2009, 02:16 PM   #10 (permalink)
Ahh..... you could do a RR then LR purge to first remove the gross air but you would then need to go back and bleed everything in proper sequence.
Old 09-29-2009, 04:12 PM   #11 (permalink)
Worm.....thats what I was thinking was probably the best idea too. Get the gross air out of the rears first, then pump the brake pedal to set the caliper pistons on all 4 corners against the new pads, then bleed several times around in sequence, using your above posted instructions. Should be good to go after that.
Old 10-05-2009, 01:26 PM   #12 (permalink)
Update.....Finished bleeding the system this weekend. Started with purging the air out of the new rear calipers from the RR, then LR and then bled in the proper sequence for my year Z. Worked well and the pedal feel is great. I highly recommend using light, rapid taps on the caliper with a rubber mallet while bleeding to help get any stuck air bubbles out
Brake Bleeding 101 jswatek1 C6 Z06 - Pit Road 12 04-15-2008 08:16 AM
Brake bleeding help jlp191@yahoo.co C5 Z06 - Pit Road 2 06-30-2007 08:57 PM
Brake Bleeding Procedure WhosUrDaddy C5 Z06 - Pit Road 12 04-13-2006 01:37 AM
WTB: Z06 rear brake calipers dbhajek Member Sales & Want-To-Buy - Parts & Cars 0 08-28-2005 11:07 AM
Brake Bleeding LtMash1A Racing 24 07-03-2003 09:22 AM
» Insurance
» Latest Auto News
Watch Australian V8 Supercars at Circuit of the Americas Live Streaming Online
This weekend, the Australian V8 Supercar Series heads to America for
Commute, Toy or Destroy VW Corrado vs. Honda CRX vs. Ford Mustang
We are back with this week’s instalment of AutoGuide’s newest,
Most Researched Cars of the Week: May 12 18
The subjects of AutoGuide.com’s most recent track shootout
» New Car Reviews
2014 Lexus IS 250 Review
From staid to sultry
2013 Buick Enclave Review
Sport compact sedan 2.0
» Featured Product
