Re: Brake cooling ducts and C5 Z06?
Originally Posted by meldog21
I have the rear Z06 18x10.5 on the front with 285/30(track) and 285/35(street) tires. The brake ducts will rub at full lock. I positioned them as well as possible and there just isn't enough room for the ducts without some contact. Even though it does rub, it only affects you at full lock when parking. My solution, don't use full lock when making a U-turn or parking. It is well worth the trade off in turning radius to have your brakes work well when pressed hard.
Dog
I can't use full lock with 9.5" stock wheels up front. Both sides hit, one more so than the other. DRM told me that this isn't uncommon.
