Brake Cooling Ducts Epic Fail - Z06Vette.com - Corvette Z06 Forum
Old 03-18-2012, 12:35 PM   #1 (permalink)
Well,
I tried to install the LG Spindle Ducts and the DRM Extensions yesterday. I have been putting this off for aquit some time just because i knew it was going to be a PITA. Well as my son would say, "dad that's a total fail".
I started by using a hand jack to get one side if the car up so I could fit the arms of the lift under the jack points. This in it's self is a PITA.
I started by removing the OE cooling ducts. Not too difficult. I had to bend them a bit and pull fairly hard but they came out. Next I proceeded to measure to cut the OE ducts. That went fine as well.
Now keep in mind I'm retired Air Force so I have access to the Auto Hobby Shop on base. They have a full implement of tools and a mechanic that works there just incase you get stuck on something. As i said before I had the car on a lift which helps tremendously. Maybe I shouldn't have told you all that, because now you are all going to really think me a big wussy. Anyway, I digress.
Now I move to the DRM extensions. They actually fit with the OE ducts and I figured out how to get them to fit in the car correctly. Now for the Spindle Ducts.
First, I was having a hard time visualizing how they went in. So I pulled a pic up on my iPhone. Thank god for Apple, I love Steve Jobs. Ok, I understand now, but here's the scary thing. I have to undo the ball joint that is attached to the lower control arm. That is a really big nut, not to mention I could really mess up the ball jont. Even the mechanic on duty said "I wouldn't do that for fear of ripping the rubber joint". I agreed as discretion is the better part of valor and that's as far as I got.
Luckily the DRM Ducts are still in new condition as well as the Spindle Ducts so they are getting shipped back to the folks and DRM and LG.
Not so lucky are my OE ducts that I just cut. Of course they don't fit any more because I just hacked the crap out of them. Fortunately my friendly mechanic was able to find, yep you guessed it, some duct tape. I was able to tape the OE ducts back together and fit them back into the wheel well. Oh, by the way, I didn't tell you that I also cut a nice opening in the OE stock opening so I could get the DRM ducts to slide through. Great, now im going to have a OE duct that flops around making more noise in an already noisy car. I just so happened to have some liquid steel in my bag of tricks (tools). I basically recreated the original hole with the liquid steel and was able to get the ducts secure.
So, lets look at what I accomplish yesterday.
I jacked my car up by hand so I could fit hockey pucks under the car and on top of the lift arms to lift the car.
I cut my old, perfectally good, functioning ducts in half.
I made a perfectly good hole bigger.
Added weight to my car by adding liquid steel and finally the best part, put duct tape on my Z. My Z06 has officially become a red neck car.
There is a sliver lining to all of this. I checked my break pads and after 5 months of running on the street and two track days last year they still had plenty of meat on them. I must be as smooth as Jenson Button because I can get three track days and five months of street use out of Hawk HPS street pads. So who needs Spindle Cooling Ducts anyway.
Yea for me!
Big Baby
2002 Z06 Black on Black
Dperreault is offline   Reply With Quote
Old 03-18-2012, 01:09 PM   #2 (permalink)
Jim Lembo's Avatar
Re: Brake Cooling Ducts Epic Fail
Unless you track your car all the time, the DRM and LG stuff is not really necessary IMO. As long as you have good BRAKE pads and your rotors are in decent shape you should not have any problems. I just hope you get a full refund from the vendors that you purchased the parts from.
Jimbo
sig by GR8 White
Old 03-18-2012, 06:48 PM   #3 (permalink)
XFordGuy's Avatar
Re: Break Cooling Ducts Epic Fail
You might want to look into the spindle adapters in my sig. They only require that you tap an unused hole. You don't have to disassemble anything.
Old 03-18-2012, 07:48 PM   #4 (permalink)
I appreciate the suggestion. I think I'm good. I'll just take it easy at the track and keep and eye on the rotors and pads.
Big Baby
Old 03-19-2012, 01:26 PM   #5 (permalink)
XFordGuy's Avatar
It sounds like you're taking it REALLY easy on the track. Do you have to turn on the hazard lights to drive that slow?
As long as you're having fun and learning, it's all good. I was at an event last year with a guy in a Ferrari F430. His experience level got him into the advanced run group, but his fear of hurting the car made him so slow that I was lapping him every 5 laps! He was not a happy guy when they moved him down to intermediate.
As you get faster, so will your BRAKE pad and rotor wear. It doesn't sound like you're there yet.
Old 03-19-2012, 03:09 PM   #6 (permalink)
HOLY SH*T! I am laughin my azz off! That is HILARIOUS!
01 QS/ModRed, Lingenfelter H/C, B&B 2-tip Bullet, Headers, hi-flow cats, x-pipe, Hurst, Vararam, DTE Stage II Diff with 3.90 gears, RSG Son of Transzilla transmission, DTE Diff Strut - 433RWHP/395RWTQ - and I DRIVE IT as MUCH AS POSSIBLE! 121K+ miles and increasing daily!
NavyPhrog is offline   Reply With Quote
Old 03-19-2012, 03:33 PM   #7 (permalink)
Z06 Tech Advisor
racingvette's Avatar
It also can be the difference in the driver style
I use less brakes, downshift more and have a longer life on rotors and pads.
Unless a car lives most of it's miles on the track those ducts are not needed.
Many race pads are designed to work better in hotter temps and so is the design of the stock rotors for the C6 Z06.
Mike M - 2001 / 2008 Z06s
Old 03-19-2012, 03:39 PM   #8 (permalink)
XFordGuy's Avatar
Umm. Hawk HPS. Did you catch that part Mike?
I'm just ribbing him. The first HPDE I ran in my Z06, I did 2 sessions in 4th gear until I knew the line. There I was in my shiny new car, wearing out my left arm pointing people by. We all started sometime.
Old 03-19-2012, 04:06 PM   #9 (permalink)
It's all good fellas,
I do take it easy at the track but I do pass some of our brothers in similar Z's, I do use a lot of down shifting and engine breaking. That's probably why my breaks are still good. Hell, im not out there on the track to set any records. Just like xfordguy said. It's all about having fun and learning. That's partly what my post is about. I was pretty much making fun of myself, if you can't laugh at yourself then you are taking life too seriously.
Big Baby
Old 03-19-2012, 04:21 PM   #10 (permalink)
XFordGuy's Avatar
I had faith that you had the right attitude. :gjob:
I post more of my F-ups than my accomplishments here. No one else benefits from hearing about how things go according to plan.
I will throw out that you can downshift early, blah, blah, blah, but the bottom line is if you are comparing your times to the guy who is using max engine brake, max mechanical brake, and minimizing braking time, you have to do the same. I get grief for rushing downshifts, but I still drive like I have a sponsor paying for this stuff.
I do short shift at 6K though. I don't have that much faith in the stock valve train. I'm not crazy
And it's "brakes" not "breaks". Lembo and I both tried to be subtle
Old 03-19-2012, 05:12 PM   #11 (permalink)
Jim Lembo's Avatar
Sometimes being subtle doesn't work. I'd much rather see Dperreault use engine braking than "break" his engine! I guess it's just the former teacher in me when it comes to spelling correctly. Like I always tell my wife, I'm an a-hole and proud of it,,,,after all, I've had 62 years of practice.
Jimbo
sig by GR8 White
Old 03-19-2012, 05:40 PM   #12 (permalink)
XFordGuy's Avatar
You da man Jim
I refined my first track car at the auto hobby shop on the same USAF base I still work at 25 years later. This thread is pure nostalgia.
Old 04-08-2012, 06:17 PM   #13 (permalink)
RJ-19's Avatar
Well when you get to the end of a long straight and are looking at a tight corner you hope you have "brakes" and not "breaks"...
Ryan J
2003 Millenium Yellow Z06
Corvette Owner Since May 2010
4,002 miles and counting...
RJ-19 is offline   Reply With Quote
Epic burnout fail YumaZ06 The Garage (non Vette related) 10 02-16-2010 11:39 AM
Brake cooling ducts and C5 Z06? usualsuspect C5 Z06 - Pit Road 4 06-02-2008 08:36 PM
Better Brake Cooling Ducts? MikeS C5 Z06 - Pit Road 2 06-10-2004 07:24 AM
New Brake Cooling Ducts! Waterfreak C5 Z06 - Pit Road 13 07-15-2003 05:59 PM
Cooling Ducts for transmission.. Zed C5 Z06 - Pit Road 6 08-15-2002 02:28 PM
» Insurance
» Latest Auto News
Toronto Police Prep Fast and Furious Blitz
Police in Toronto, Canada are preparing for the release of Fast and
2014 Jeep Patriot Freedom Edition Revived
Just in time for Memorial Day, Jeep has reintroduced a special 2014
2014 Fiat 500L Starts at $19,100, Arrives in June
The Fiat lineup is growing with the addition of the 500L which will
» New Car Reviews
2013 Nissan Pathfinder vs 2013 Hyundai Santa Fe
Family faceoff: Comparing the two newest three-row crossovers
2013 BMW X3 xDrive28i Review
2014 Scion tC Review - Video
2014 Lexus IS 250 Review
From staid to sultry
» Featured Product
