Old 08-07-2005, 09:09 AM   #1 (permalink)
Bob
Brake Fluid on Calipers
Is it OK if you get a little brake fluid on the calipers when bleeding them, or will the fluid melt the caliper paint? I wiped off the excess fluid, but I did not have any cleaner handy. What would you use to clean the fluid off the caliper?
Old 08-07-2005, 10:08 AM   #2 (permalink)
Windex, 409, Simply Green. Brake fluid will damage paint. The paint on your calipers is different I believe it contains an epoxy. But, it's still paint and can be damaged.
Chas.
wlxx861 is offline   Reply With Quote
Old 08-07-2005, 09:28 PM   #3 (permalink)
That paint on the calipers is pretty tough, untill you just turn the calipers black from excessive heat on the track.
Soap and water or whatever you have laying around will clean them up ok.
Best 17" Wheel brake calipers? Greg Koning C5 Z06 - Pit Road 5 10-24-2007 08:43 AM
WTB: Z06 brake calipers culookin Member Sales - Parts & Cars 6 01-09-2005 01:55 PM
Flushing Brake Lines & Calipers & How Much Fluid Does The Differential Hold? ZBESTC5 C5 Z06 - Pit Road 32 05-26-2004 10:08 PM
Red paint for Brake Calipers? Brad03 C5 Z06 - Grandstand 5 03-26-2004 05:58 PM
Brake Fluid and Clutch Fluid Z OOH 6 C5 Z06 - Pit Road 14 11-19-2002 09:07 PM
