Old 10-15-2002, 10:49 AM   #1 (permalink)
Send a message via AIM to Z OOH 6
Is this brake fluid ok for replacement in my car?
http://www.turnermotorsports.com/det...ODUCT_ID=ATESB
I have this laying around from my BMW when I was going to install the stainless steel brake lines on it. Would this be ok to 'mix' in w/ the stock fluid in the brake reservoir?
After reading a few posts, I checked my brake fluid reservoir and the fluid is yucky black! I have a turkey baster to take it out and add this new fluid w/o any need for bleeding the brakes.
Z OOH 6 is offline   Reply With Quote
Old 10-15-2002, 11:31 AM   #2 (permalink)
Z OO, I would not.........it's Dot 4, and if your is this funky..........change it all.............
Old 10-15-2002, 03:29 PM   #3 (permalink)
Could I change it w/ this one? If so, will 1 Liter of this stuff do the entire system?
Old 10-15-2002, 03:39 PM   #4 (permalink)
Send a message via Yahoo to pmontelo
You can use it, and it will mix just fine with DOT 3. A complete bleed including the ABS is best, but is not required. The Ate Super Blue fluid is what several members are using. I am using the same stuff only in Amber color, it's called Ate Typ 200.
Brake & Clutch Partial Fluid Change
http://www.swedishbricks.net/700900F...Comparison.htm
http://www.shotimes.com/SHO3brakefluid.html
http://www.rpmnet.com/techart/fluid.shtml
pmontelo is offline   Reply With Quote
Old 10-15-2002, 04:42 PM   #5 (permalink)
1 liter will flush the entire system no problem. I use the ATE super blue with no problems. If the can has been sealed then its fine to use it, if it was opened before I would not use it. Moisture might have got into it. I would also suggest using www.speedbleeder.com they are great. You should also get all of the fluid out of your clutch reservoir, wipe out with a paper towel and fill with some valvoline syntic, I did a complete clutch system flush and put the ATE super blue in the reservoir.
Replacement Power Steering Fluid? EFI-1 C5 Z06 - Pit Road 7 09-14-2004 10:39 PM
How often should I flush my brake fluid if I track the car? xsiveone Racing 19 04-10-2004 11:44 AM
How Much Brake Fluid & SS Brake Lines? II on 6 C5 Z06 - Pit Road 6 07-25-2003 06:52 AM
Brake Fluid and Clutch Fluid Z OOH 6 C5 Z06 - Pit Road 14 11-19-2002 09:07 PM
Clutch Brake Fluid Replacement ZO6/Les C5 Z06 - Pit Road 13 07-01-2002 04:45 PM
