Old 09-02-2002, 11:01 AM   #1 (permalink)
Brake Pad pads and Rotor rotors change w/ Some pics
Brake Caliper Bracket Replacement - Front
Removal Procedure
Caution
Do not move the vehicle until a firm brake pedal is obtained. Failure to obtain a firm pedal before moving vehicle may result in personal injury.
Remove the brake caliper from the mounting bracket and support the brake caliper (2) with heavy mechanic's wire (1), or equivalent; do NOT disconnect the hydraulic brake flexible hose from the caliper. Refer to Brake Caliper Replacement - Front .
Watch your brake reservoir level, when you compress the caliper pistons the fluid level will increase in the reservoir.
Install large C-clamp (2) over the body of the brake caliper (1) with the C-clamp ends against the rear of the caliper body and against the outboard brake pad.
Tighten the C-clamp (2) evenly until the caliper pistons are compressed into the caliper bores enough to allow the caliper to slide past the brake rotor.
Remove the C-clamp from the caliper.
Remove the brake pads (2) from the brake caliper bracket (3).
Remove the brake pad retainers (1) from the brake caliper bracket (3).
Caution
These fasteners MUST be replaced with new fasteners anytime they become loose or are removed. Failure to replace these fasteners after they become loose or are removed may cause loss of vehicle control and personal injury.
Remove the brake caliper mounting bracket bolts and washers.
Discard the brake caliper mounting bracket bolts. These bolts are 21mm and are very tight.
Remove the brake caliper mounting bracket from the knuckle.
Inspect the brake caliper bracket.
Replace the brake caliper bracket if cracked or damaged.
Clean all the bolt adhesive residue from the brake caliper mounting bracket and the knuckle mating surfaces.
Remove the rotor retainers with a 3/8" deep socket applied with lite hand pressure to get them started, Then with gloves on turn and pull the retainers off.
Remove the brake rotor.
Installation Procedure
Important
Whenever the rotor has been separated from the wheel bearing flange, clean any rust or contaminants from the wheel bearing flange and the brake rotor mating surfaces. Failure to do this may result in increased lateral runout of the brake rotor, and brake pulsation.
Use the J 42450-A in order to clean any rust or corrosion from the wheel hub surface. I just used a wire brush to clean the area.
Install the brake rotor over the wheel studs onto the wheel bearing flange.
Install the brake caliper mounting bracket to the knuckle. the part # for the new bolts are 14067559.
Caution
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the two NEW brake caliper mounting bracket bolts and washers. The new brake caliper mounting bracket bolts will come with an adhesive already applied to the threads. Tighten
Tighten the front brake caliper mounting bracket bolts to 175 N·m (125 lb ft).
Lubricate the brake caliper pin bolts with high temperature silicone lubricant.
Install the brake pad retainers (1) to the brake caliper bracket (3).
Install the brake pads (2) to the brake caliper bracket (3).
Install the brake caliper. Refer to Brake Caliper Replacement - Front .
With the engine OFF, gradually apply the brake pedal to approximately 2/3 of its travel distance.
Slowly release the brake pedal.
Wait 15 seconds, then repeat steps 11-12 until a firm brake pedal apply is obtained; this will properly seat the brake caliper pistons and brake pads.
Fill the brake master cylinder reservoir to the proper level. Refer to Master Cylinder Reservoir Filling in Hydraulic Brakes.
Burnishing Pads and Rotors
Road Test Safety Caution
Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage.
Burnishing the brake pads and brake rotors is necessary in order to ensure that the braking surfaces are properly prepared after service has been performed on the disc brake system.
This procedure should be performed whenever the disc brake rotors have been refinished or replaced, and/or whenever the disc brake pads have been replaced.
Select a smooth road with little or no traffic.
Accelerate the vehicle to 48 km/h (30 mph).
Important
Use care to avoid overheating the brakes while performing this step.
Using moderate to firm pressure, apply the brakes to bring the vehicle to a stop. Do not allow the brakes to lock.
Repeat steps 2 and 3 until approximately 20 stops have been completed. Allow sufficient cooling periods between stops in order to properly burnish the brake pads and rotors.
Old 09-02-2002, 11:20 AM   #2 (permalink)
many of us already know this but to a novice you give very good and professional directions, excellent attention to detail. very nice pics ..............clean those pretty red calipers he he he he he
corvette184 is offline   Reply With Quote
Old 09-02-2002, 03:20 PM   #3 (permalink)
Nice Job!!
Fast Eddie is offline   Reply With Quote
Old 09-02-2002, 03:40 PM   #4 (permalink)
Great reference for us "shadetree" mechanics..... I'm gonna post a copy in the Tech Tips section if you don't mind. Thanks for taking the time to post this gmblack3.....
NCM Member #9943
AgentZ06 is offline   Reply With Quote
Old 09-02-2002, 07:14 PM   #5 (permalink)
DJWorm's Avatar
If you are going to change the pads, you of course need to loosen the Caliper pin bolts to take the rotor off and change the pads.
If you are going to change the rotors AND pads you can just remove the caliper mounting bracket bolts to do both, there is no need to remove the caliper from the bracket.
And while your there doing all this. spend about $11 a wheel and install speedbeeders.
www.speedbleeder.com
Old 09-02-2002, 08:34 PM   #6 (permalink)
DJ, I had gave that a thought but was not sure. Thanks!
Brake Pad pads change w/ some pics gmblack3 C5 Z06 - Pit Road 25 06-03-2008 07:07 AM
New Brake Rotors and old pad.... SexyLex C5 Z06 - Pit Road 9 05-27-2005 07:10 PM
Questions Re: Brake Pad and Rotor Change Bob C5 Z06 - Pit Road 7 09-05-2004 05:28 PM
WTS Brake Pad and Rotors urpow Member Sales - Parts & Cars 1 07-17-2003 11:31 AM
DIY: Brake Pad pads and Rotor rotors change w/ Some pics gmblack3 Z06Vette DIY Information 6 09-02-2002 06:01 PM
