Old 11-11-2003, 02:21 PM   #1 (permalink)
Brake pad swap help?
I am planning on going to dura-stop pads anybody have the shop manual pages for the step by step way to change front and rears? I have done brakes jobs before but never on a vette, I would like to look it over before I tear into it......
Thanks,
Dave
dheller1 is offline   Reply With Quote
Old 11-11-2003, 02:53 PM   #2 (permalink)
The pads on the Z are very easy to replace. Jack the car and support on jack stands. Remove wheels. Front calipers, just remove bottom slider bolts and rotate caliper backwards on the other bolt. Remove / reinstall new pads and reinstall caliper. The rears will require you to remove both caliper bolts as the hose is not long enough to get the amount of rotation required to remove pads. The entire operation should not take longer than an hour.
CHJ In Virginia is offline   Reply With Quote
Old 11-11-2003, 04:36 PM   #3 (permalink)
Brake Pad pads change w/ some pics is a pretty good tutorial with pictures.
Old 11-11-2003, 04:39 PM   #4 (permalink)
Just make sure you see how the clips go in as you remove the old ones. And for getting the caliper and new pads back on the rotor, don't compress the piston too much or it will force fluid out of the resevoir. I've only done it once and those are the two issues I had. Do what I did and have somebody that has done it watch you. Right, Brian?
Good luck.
"ROSSO Z"
Pull after pad & rotor swap jlucas Racing 6 09-27-2006 07:42 PM
ceramic brake pad better? SS#1230 C5 Z06 - Pit Road 18 07-13-2004 09:37 AM
Brake Pad Retainers DavePro The Garage 1 10-23-2003 01:55 PM
Brake pad Primer DJWorm C5 Z06 - Pit Road 0 10-09-2003 10:33 AM
'02 brake pad part #? Lawdogg C5 Z06 - Pit Road 2 05-29-2002 02:42 PM
