Broken Piston tear down - Z06Vette.com - Corvette Z06 Forum
Old 12-03-2012, 01:23 PM   #1 (permalink)
Big Baby
2002 Z06 Black on Black
Dperreault is offline   Reply With Quote
Old 12-03-2012, 02:25 PM   #2 (permalink)
XFordGuy's Avatar
Re: Broken Piston tear down
Good job so far!
(AKA Jon) 2002 EB Z06, LTPWS, K&N, CLB, T1 bars, Pfadt spherical bearings, DRM brake pistons/brake ducts, Phoenix spindle adapters, Ron Davis radiator/EOC, Carbotech pads, Goodridge brake lines, Stainless Speedbleeders, Elite Engineering Heel-Toe pedal/oil catch can/radiator screen, TurnOne PS pump, Optima red top, C6 Z06 Shifter, Corbeau A4s, BK Harness bar and belt mounts, Simpson 5 pt harnesses, Amsoil. It all started with the CAGS eliminator...
Old 12-03-2012, 03:07 PM   #3 (permalink)
Originally Posted by XFordGuy View Post
Good job so far!
I know, anyone can take stuff apart but can it go back together? We will see.
Big Baby
Old 12-03-2012, 05:28 PM   #4 (permalink)
Jim Lembo's Avatar
That broken piston looks VERY familiar. What does the #7 Cylinder look like and also the combustion chamber and valves for #7,,,,,how did they fare when the pston broke?
sig by GR8 White
Old 12-03-2012, 08:15 PM   #5 (permalink)
Surprisingly the cylinder wall is untouched. I was due a bit of luck after this disaster.
Here is a shot of the combustion chamber and valve tops.
The machinist said some of the nicks will come out in the when he machines the head.
Big Baby
Old 12-04-2012, 07:09 AM   #6 (permalink)
Jim Lembo's Avatar
Chamber looks almost identical to mine, shouldn't be too hard to clean it up.
While you got everything apart it might be a good idea to replace all your internal fasteners to ARP. (rod bolts and main bearing fasteners).
Are you going to get the heads done while they are off? Valve job, new seals/guides and maybe a slight milling to up the compression a bit? IMO, it would be money well spent and definitely enhance performance.
sig by GR8 White
Old 12-04-2012, 10:54 AM   #7 (permalink)
The heads are at the shop right now. 3 angle valve job and a mill on the faces. Surprisingly he checked out the valves and they were all straight. He's going to double check them since I dropped my old piston off to get pressed in to the control arm and seen the half moon mark in the crown.
I'm going to have my tuner bump the RPM down a couple hundred so we don't have this problem again.
Big Baby
Old 12-04-2012, 11:58 AM   #8 (permalink)
Z06 Tech Advisor
racingvette's Avatar
Rev limiter has nothing to do with the failure as stock is 6,600 and many of us run around 7,000 for years with no problems
As stated in your other thread on this I mentioned broken ring land as your #7 is proven to be due to bad tuning and too small of fuel injectors
Your pictures show this failed some time ago and driven that way over time
Being it was not tripping CEL and flashing for a P0300 says the old tuner turned off misfires function in PCM so real misfires were ignored by the PCM to prevent it from reacting to misfires and hence real misfires would cause out of timing of valve face kissing piston
You can bet they also detuned engine knock protection which would add to the piston slap damaging ring land.
Th past tuner was trying to hide/mask problems and caused the long term damage
Ring land breaks from that cylinder running way lean and causes cylinders temps to run way hotter over a good amount of time
If your thinking is reduce engine design by lowering rev limiter as protection to this failure assures it will happen again without doing as suggested several times in larger fuel injectors and then retuning for them
If rev limiter setting was the sole cause then ALL pistons over time would show at some point valve kissing piston top and possible the valve springs used were wrong for the CAM grind/lift and/or wrong length pushrods.
Mike M - 2001 / 2008 Z06s
Old 12-04-2012, 12:24 PM   #9 (permalink)
I understand what you're saying. Unfortunately, all of the pistons have been kissed by the valves some more than others.
So that's telling me that not only did the tuner turn off all of the warning codes but the RPMs were also too high for the springs in the valve train. Me and my buddy are going to try to determine the lift and duration of my Cam and make appropriate changes to the valvetrain if necessary.
I am also planning on bringing my fuel injectors to my tuner and having him pump them up to 36 pounds, after everything is put back together. I certainly don't want a repeat of this disaster.
On a different note. I really would like to pull the Billy boat bullets off my car as they are way too loud. If I put the stock titanium system on my Z would that caused a problem with airflow since I have long tube headers, high flow cats, and that high duration and lift cam?
Big Baby
Old 12-04-2012, 01:09 PM   #10 (permalink)
I would be interested to hear the response to this as I have been having the same question lately. Thanks for posting the pics, looks like it could have been a lot worse than it was.
2007 Z06- Lingenfelter 660 package (569 RWHP, 500 RWTQ)
2012 Fiat 500 ABARTH
2008 Ducati 1098 and 2007 Kawasaki ZX-6R
2006 Honda Civic Si
DucZ06 is offline   Reply With Quote
Old 12-04-2012, 01:25 PM   #11 (permalink)
MikesZ06's Avatar
As I told Dperrault in a pm, I don't believe the stock titanium exhaust restricts the air flow at all. If they did, you would see power gains with just aftermarket cat backs and you don't.
My suggestion is to slap on some Borla cat backs. Not nearly as rowdy as the BB's but a nicer sound IMHO than the oem. Some folks like the Corsa system too But I prefer the Borla's.
Vette Magazine article
1/4 mile pass
Old 12-04-2012, 02:48 PM   #12 (permalink)
Z06 Tech Advisor
Due to the fastburn head design for the LSx engines and even stock CATs today the flow is pretty good and not a lot of backpressure
So mufflers themselves will not produce more HP and brand/type of muffler is more about the quality of sound the owner likes.
What can be an issue is seeing the amount of carbon build up on your valves and piston tops that
1. past owner was lazy and never did common maintenance in using a good decarb cleaner
2. That tune and mods were not matched well forcing a too lean of condition that the PCM non stop could not correct the AFR and thus was dumping in more fuel when it was not needed and causing CATS to run too hot causing the PCM to trigger the CAT overtemp protection which was dumping in even more fuel to try and cool CATs down
End result of that along with carbon build up is caking up the CATs, (they might have even been breaking up and clogging the mufflers) and corrupting the O2 sensors.
As much as the junk said in cyberspace USE also the rear 02 sensors even if not using CATs as the GM PCMs use the rears for short term fuel trims and what average fuel injector pulse width ON times for each drive cycle.
You would be real wise at this point to make the effort and verify 02s, CATs and existing mufflers are in good working condition and best is to replace at least both front 02s.
If your looking for gains replace both CATS with a true X-pipe at that location thus existing exhaust pipes and catback can be used.
This will increase the low end torque and change the sound of exhaust.
As to catback change the thought would be weight saving as stock system is about 75 lbs and other designs can cut that weight in half.
Rev limiter reduction is not the fix, the path is use a pushrod length tester to assure proper length rods are used and better vale springs
The later beehive designs work well
Dual spring is more about harmonics of the thin inner spring and not as much to prevent valve float.
If you want to prevent end cylinders from being too hot/lean the coolant lines the LS1 had do just that by the flowing water pulls heat out or
install water methanol injection even with a NA engine will pull 40 plus temp degrees out of cylinders and is cheap in long term costs.
Decent kits are less then $500 and trigger off the MAF output signal so can be adjusted to flow only when in upper engine loads
Old 12-04-2012, 03:04 PM   #13 (permalink)
Z06 Tech Advisor
Would be smart is spending like $45 and places like Radio Shack sell a sound DBa test meter.
Consider the noise standard/laws, maximum DBa allowed is 94 Dba
With tester check other Corvettes at idle ( meter 45 deg angle to exhaust tips) using different muffler designs
If you want SAFE sound you want no more then about 82 Dba within drivers area. That would be safe for 8 non stop hours of driving
Every 2 Dba gain from that cuts down the maximum allowed time by half.
Once ears are damaged by high Dba there is no fix to repair hearing damage, just ask any of us hardcore racers :-(
If considering using a true X-pipe close to engine install that first with existing mufflers as sound will change and then decide on if another design of muffler is wanted.
A cheap fix is instead of replacing expensive catback is to install a bullet pre mufflers in drivetube area, they will not increase backpressure if good ones are used and will lower then DBa output of mufflers you have now.
Old 12-04-2012, 04:27 PM   #14 (permalink)
Since I have decided to keep my Z. I just made the decision today to replace all the pistons with a flat head OEM spec after market replacement. This was a tough decision as I'm well over budget but in the long run it will be right. This will give me the best starting point with a fresh engine, just short of pulling the engine, which I'm not going to do. I'm happy with and in-engine Overhaul.
I'm going to get this Z to where it should have been when I bought it.
If you had $400-$500 what brand of piston set would you recommend? I plan on measuring the cylinder bore this weekend to make sure I'm within specs of an off e shelf piston.
Do you know the specs of our stock pistons. Unfortunately, all the number are Greek to me but my buddy mechanic will know.
Thanks.
Big Baby
Old 12-06-2012, 10:49 AM   #15 (permalink)
Here's an update on my engine in-frame overhaul. I've decided to replace all eight pistons with a good set of forged pistons. My buddy is coming over Saturday and we are going check the bore stroke so we ensure we get the correct size pistons.
We are also going to try to determine the lift and duration of my existing cam . This will tell me whether or not I have the correct pushrods and also the proper springs in the valvetrain.
I am also replacing all four oxygen sensors just in case they were fouled by what racingvette was saying.
My heads are currently at the machinists getting milled and a 3 angle valve job. In the end I will have a brand-new engine when it's all said and done. I'm actually getting very anxious to get it all back together so I can see how she'll run
On a positive note, I did find a nice set of stock titanium mufflers a few hours away from me and I'm picking them up on Sunday. So my days of enduring the extremely loud bullet exhaust will come to an end.
Big Baby
Broken Piston & Floated Valves Dperreault C5 Z06 - Pit Road 20 11-07-2012 08:58 PM
warranty on Wear and Tear jjm The Garage (non Vette related) 1 11-29-2005 10:32 AM
tear in driver seat mmorse C5 Z06 - Grandstand 14 09-19-2003 05:49 PM
WILWOOD Z06 6 Piston Front/4 Piston Rear Braking Systems...GP GOING ON NOW!!! L.A. Performance Division Vendor Sales - C5 3 09-01-2003 03:12 PM
NOW AVAILABLE...WILWOOD Z06 6 Piston Front/4 Piston Rear Braking Systems... L.A. Performance Division Vendor Sales - C5 13 08-05-2003 04:06 PM
» Insurance
» Latest Auto News
Mazda to Debut New Model on Xbox Live
Mazda has teamed up with Xbox to produce the first-ever global live
2014 Aston Martin Vanquish Volante is Dripping With Sex Appeal
Aston Martin has just unveiled its 2014 Vanquish Volante, the first
Five-Point Inspection: 2013 Fiat 500e
As fuel prices continue to test the limits of infinity, small cars are
» New Car Reviews
2013 Honda CR-Z Review
Not hot enough and not eco-enough
2014 Mercedes-Benz E350 Wagon Review
Wagons East: This Benz is Sweeter than Candy
2013 Audi RS5 Review - Video
The last of a breed and the best of the bunch
2014 Chevrolet Impala 2.5L 4-Cyl Review
Are four cylinders two too few for Chevy's new sedan?
2014 Kia Rondo Review
You can't buy it, but do you even want to?
» Featured Product
