Old 03-05-2003, 05:17 AM   #1 (permalink)
Send a message via Yahoo to R/ZO6-LS6
Burnt Clutch Smell "HELP"!!!!!!!
Last Night I Got on it pretty hard. Went up in smoke in 1st, Went into 2nd pretty hard, and the Clucth just Slipped (I Think). Smelled really burnt. My Question is What did I damage? I only have 3300mi. on this car HELP!!!!!!
rz06Hurst Billet Plus.CAGS-Bypass,CarbonFiber Power Duct, Carbon Fiber Phantom Shifter Knob, Red Smooth ,coupler,Chome Ram-Air Intake System,Front & Rear Spoiler Reinforcements,Hood Seal, Door Seals, ZO6 Exhaust Enhancement Plate,Carbon Fiber Front Mask,Screens, Hardtop Partition, Deck Lid Liner. Bassini X-Pipe,Carbon Fiber Black-Outs, Cromies,Borla Stingers 2-Tips,
R/ZO6-LS6 is offline   Reply With Quote
Old 03-05-2003, 07:08 AM   #2 (permalink)
DJWorm's Avatar
If it's only smell its probably OK.
But if the clutch pedal starts sticking to the floor when hot.....that's another story.
Old 03-05-2003, 07:09 AM   #3 (permalink)
If you were smelling clutch you hurt the clutch. Look at it this way. On most cars the weakest link is the tires to protect your drivetrain. You smoked the tires in first then threw all that rotating power against second. For all I know you might have had been slipping the clutch through first but, in-any-event ,the tires hooked and your last line of defense kicked in before damage resulted or, the clutch burnt some. It's ok to burn a clutch sometimes but when you do the heat is awful. Do it enough and this heat will warp, blue, basically screw up, your whole clutch assembly instead of just wearing the disk out. Many people tell me the clutch is poor on the 06. Maybe your just ready for a new one? Mike
Joslyn is offline   Reply With Quote
Old 03-05-2003, 10:25 AM   #4 (permalink)
Hey thanks for your input,Do you know if there is a check plate on the Bellhousing or not? Iam not sure because I havent been under it in awhile.
Old 03-05-2003, 10:27 AM   #5 (permalink)
Send a message via AIM to ZO6 DUST Send a message via Yahoo to ZO6 DUST
I smoked my clutch one weekend afternoon, practicing a burnout for the strip in a empty parking lot. I forgot to engage the Competitive Driving Mode.
The smell eventually went away three days later, but once a clutch gets that hot, it more than likely will warp the fingers, a weak point IMO. Also the Clutch Disc Plate will tend to loose it roughness and smooth out, eventually leaving you with a ruptured seal allowing air into the system (sticking clutch pedal) or a clutch pedals that slips (no crisp engaging point).
At the present time there is no need to worry, just know, depending on how hot it got, you may have an issue later down the road. Good Luck!
475 RWHP, 426 TRQ. / Magnuson
570 RWHP, 589 TRQ. / N2O
Heads I Win, Tails You Lose
ZO6 DUST is offline   Reply With Quote
Old 03-05-2003, 10:29 AM   #6 (permalink)
Ohh yeah...if you have clutch work done under warranty, they will charge you seperate to remove aftermarket headers to remove the bellhousing.
"Matches" smell after spirited driving? bigcat39 C5 Z06 - Pit Road 12 03-03-2006 11:36 AM
Burnt clutch smell after drag strip run.. Any Idea's??? 00Vette C5 Z06 - Pit Road 2 07-13-2005 11:35 PM
SPEC Stage 111 "Plus" Clutch SPRFAST C5 Z06 - Pit Road 1 05-27-2005 09:38 PM
I think my new clutch is glazed... is it ruined, or can I "fix" it? Cobra4B C5 Z06 - Pit Road 2 02-09-2005 10:18 AM
"Side-stepping" or "slipping" the clutch... Young_Jedi Racing 3 04-29-2004 03:32 PM
