C5 engine removal from top!!!! - Z06Vette.com - Corvette Z06 Forum
post #1 of 6 (permalink) Old 12-28-2010, 01:56 PM Thread Starter
Can i just separate the torque tube from the housing by taking out the 5 13mm bolts, then jack up the torque tube as far as it will go, then attach hoist to engine, then jack up motor off mounts, then slide motor forward off the driveline input shaft and lift out.
Or will that not work??....I don't want to drop subframe/cradle/or remove rack
Or what is the easiest way to take LS1 out of the top with removing as little large components as possible.....ie can I skip the removal of the steering rack, cradel/subframe/ or a-arm joints if anything at all.
This is being done on a drive way
redbeast215 is offline
post #2 of 6 (permalink) Old 01-26-2011, 07:57 AM
Re: C5 engine removal from top!!!!
It can be done, but it's much easier to lower the sub-frame a little bit.
dennyf is offline
post #3 of 6 (permalink) Old 01-26-2011, 09:01 AM
Jim Lembo's Avatar
You are going to have a very hard time getting it out the top without removing the steering rack. And of course you are going to have to remove the radiator/fans and it might be a good idea to remove most of the front accessories too. The motor has to come forward quite a ways to clear the torque tube input shaft. Taking it out the bottom is definitely the best way to do it, but I realize if you're doing it outside in your driveway that is pretty near impossible unless you can get the car at least 3 feet off the ground.
Good luck and be careful!
Jimbo
sig by GR8 White
'03 EB/mod blue, LME/V-Max 416, AFR 225's, Comp Custom cam from Pete at V-Max, 3" custom exhaust and lots of attitude! 10.47@133.38 :D Z06 Fest member III, IV, V, VI, VII, VIII, IX, X, XI, XII and Winterfests 1, 2, 3 & 4. 543rwhp/493rwtq, all motor!
Jim Lembo is offline
post #4 of 6 (permalink) Old 01-26-2011, 01:11 PM
PerforminNorman's Avatar
Took mine out the top. If I had to do it all over again, it would come out the bottom.
LS15 Power! LS2 + LS6 + LS7 = LS15.
PerforminNorman is offline
post #5 of 6 (permalink) Old 01-26-2011, 01:22 PM
If you're doing it in the drive way, all I have to say is good luck. Watch the firewall!
jub jub is offline
post #6 of 6 (permalink) Old 12-09-2013, 08:04 AM
YumaZ06's Avatar
Location: Yuma, Az. ?????? Z06 Fest IV, V, VII, VIII, IX, X, XII & Winterfest 1,2,3 & 4
It probably would be a good idea to take off the front clip if you are using a roll around cherry picker to remove the engine. Someone I know had a shop remove it from the top and they banged up the front bumper cover real bad trying to get the hoist close enough to get the engine out. :eek2:
2004 MS/BLK
YumaZ06 is offline
Engine removal out the top or bottom? whataz06 C5 Z06 - Pit Road 11 12-28-2010 01:36 PM
Engine removal - can I do this? WayneE C5 Z06 - Pit Road 7 12-08-2006 10:23 AM
Engine removal Ronnie_W C5 Z06 - Pit Road 3 10-14-2003 04:09 PM
2003 z06 top speed limiter removal??? Ianz06 C5 Z06 - Grandstand 24 08-14-2003 04:43 PM
Engine removal - up or down? jeclarke C5 Z06 - Pit Road 3 04-15-2002 12:46 AM
