Old 09-10-2004, 02:55 PM   #1 (permalink)
C5R Oil Starvation?
I was up at Road Atlanta this afternoon talking to a Corvette racer, and he mentioned that a friend had lunched his C5R block-based race engine due to oil starvation under hard cornering. Supposedly, this was caused by the larger oil passages in the C5R block. The conventional wisdom in his crowd was that C5R-based engines should be dry-sumped. I only do track days with my car, so is this something I should worry about? I'd hate to lose a big buck engine.
98 Silver M6, C5R 427, LS7 Heads, F1C Procharger. 788 RWHP at 8 PSI, no methanol.
marco383 is offline   Reply With Quote
Old 09-10-2004, 03:04 PM   #2 (permalink)
I was advised to add an accusump (3 quart) on my stock LS-6, and think it's cheap insurance for any car doing sustained lateral g's.
The guys at Phoenix Perf mounted it in the left inner fenderwell just ahead of the door, and a stand alone oil cooler up front.
Same setup that Dave P. and Subdriver have on their T1 cars.
Arnoldir is offline   Reply With Quote
Old 09-10-2004, 05:39 PM   #3 (permalink)
I think running it one quart above the full mark for occassional D.E. days should be adequate.
More serious racing might call for something more.
Pat
02 EB/Mod Red, LPE C5R 427 Twin Turbo, Kirban/Delrin, Brembo, HRE, 665 rwhp, 702 rwtq without variable boost.
Mufflerbearing is offline   Reply With Quote
Old 09-10-2004, 05:59 PM   #4 (permalink)
Big dollar motor definately get a Accusump. They work great! DRM sells a kit.
Old 09-11-2004, 05:53 AM   #5 (permalink)
DJWorm's Avatar
It would be interesting to know what type of pan was used on that C5R block.
Actually the improvements to the LS6 block and the C5R block over the LS1 block lessen the chance of oil starvation.
A tracked car at the very least should have an Accusump, Ported oil Pump and have a cooler.
A dry sump is best. I like the Billet, 4 pick-up pan from KaTech the best.
KaTech as well as ARE has 2 pick-up dry sump pans. I like Peterson parts for the rest of the system.
AMSOIL Online Store
Old 09-11-2004, 06:27 AM   #6 (permalink)
Based on the advice above, I'll be installing an Accusump. Given my observed oil temps to date (max. around 275), I think I'm OK without a cooler. For what it's worth, the C5R block just uses the stock LS1 oil pan.
Thanks for the input!
Old 09-11-2004, 08:19 AM   #7 (permalink)
Marco,
My routine with the Accusump is to shut down the valve before shutting off the engine, then turn on sump and count to 10 before starting.
For normal street, I shut the valve back down as I pull away and leave it off. If I get stuck in traffic, or before parking it I will open the valve at idle and bleed some cold oil back into the motor. If you watch the oil temp you will see a 5-7 degree drop. as soon as the temp starts to rise again I close the valve.
Old 09-11-2004, 08:41 AM   #8 (permalink)
DJWorm's Avatar
It's advisable to install an engine oil cooler at the same time as the Acusump as it is all the same dircuit.
Was that OEM pan the 4 level Corvette pan with wiing reservoirs or the open Camaro pan?
Old 09-11-2004, 10:00 AM   #9 (permalink)
It's the Corvette pan. BTW, I checked Rippie's website and can't find a reference to the Accusump kit. I'll call them on Monday.
Old 09-14-2004, 06:46 PM   #10 (permalink)
Can someone give me a link to DRM??
2003 blk/blk Z06. 436 RWHP, 398 RWTQ NA
Mods: AFR Heads, .226/.228 114 LSA Comp cam, LPE oil cooler, hi flow oil pump, FAST 87 mm manifold, polished and ported Tbody, K&N intake, LT headers (powder coated), ACP ventilated hood
PGHZO6 is offline   Reply With Quote
Old 09-14-2004, 07:51 PM   #11 (permalink)
I'm in the process of gathering up a parts list to piece together my own Accusump kit (3 qt w/ electric valve). I plan on using a T-fitting to plumb it into my existing LG oil cooler/radiator. Will post pics once I get it done - hopefully in the next few weeks.
Joe
My Garage
Old 09-14-2004, 09:47 PM   #12 (permalink)
DJWorm's Avatar
www.dougrippie.com
Old 09-14-2004, 09:50 PM   #13 (permalink)
MikesZ06's Avatar
Originally Posted by DJWorm
Well, that's one way to do it....
9.87 at 141mph
& 2007 Black C6 Z06
Fuel starvation issue Konomi C5 Z06 - Pit Road 5 01-27-2006 12:07 PM
Oil Consumption C5r 427 husker brian C5 Z06 - Pit Road 8 02-23-2005 07:26 AM
P0157 and fuel starvation Redshift C5 Z06 - Pit Road 9 02-16-2004 12:49 PM
Oil Starvation Prevention Program 03 EB Z C5 Z06 - Pit Road 7 09-20-2003 05:22 PM
NEW @ PFYC.com: Bi-xenon HID, TPIS, Random Tech, Quick Oil Change, CarChip, C5R Stuff Redshift Vendor Sales - C5 3 04-24-2003 02:00 PM
