Old 08-18-2003, 10:19 AM   #1 (permalink)
Cam Goodies
Planning on getting the X1 cam from MTI in the next couple weeks and was wondering if I needed to go ahead and get underdrive pulleys (289+installation), ported oil pump (100+installation), and double roller timing chain (150+installation)?? Are these things completely necessary, or more of a precaution? Which one or two would benefit me more if I didn't do all three of them? Thanks
Edit: Almost forgot, I have heard that it is better to go with the stock pushrods, instead of the hardened or the chromoly ones if you are doing a cam only? What do you guys think?
03 RED Z MAN is offline   Reply With Quote
Old 08-18-2003, 10:36 AM   #2 (permalink)
Z MAN, I did all of the above with my cam install.
It is cheap insurance, while they are in there have them replaced.
I did not get the under drive pulley, I could not justify $300 for 5 rwhp.
Hope this helps.
D.
Halltech TRIC, Borla Quads, FLP long tubes,228 228/588/588@112 lsa, Spec Stage III clutch, Hardened output shaft, 4.10 gears, Wolfe rollbar, 2004 sachs shocks. 416 rwhp Motor only 530 rwhp on juice
DBarbosa is offline   Reply With Quote
Old 08-18-2003, 10:38 AM   #3 (permalink)
Sorry my bad, I went with a stock GM chain, My installer has never seen a prob. with a stock chain as far as breaking.
I am at 416.3 rwhp and have had no prob.
I jinxed myself now.
D.
Old 08-18-2003, 10:57 AM   #4 (permalink)
I really don't think that the ported oil pump is worth the$$. I got one from katech and disassembled it. Very little is touched in the port. The whole oil pump fear is because the pre 01 had some high rpm problems. As far as timing chain... I almost always re use stock. H/C cars at 461 rwhp no problem, ATI supercharged/cam no problem. You could install the GM timing chain tensioner. I have yet to use one but I have seen them and I want to try it out. The only time that I use hardened pushrods is when I have milled heads requiring a different than stock length. Or on a solid roller. The stock pushrods have been good to 7000 rpm on hydraulic cams in the .588 lift area. I hope this helps
Antivenom is offline   Reply With Quote
Thanks for the goodies at the Fest! S-TEE The Car Wash 8 08-07-2006 06:48 PM
New goodies! dmtnt C5 Z06 - Pit Road 5 03-28-2005 12:15 PM
...More On Pricing (and a few other Goodies) Z06 Tom C6 Z06 - Pit Road 1 01-02-2005 06:00 PM
new goodies corvette184 Vendor Sales - C5 7 01-15-2003 08:24 AM
All my goodies are on ! azzkiknZO6 The Garage 3 11-25-2002 12:36 PM
