Old 12-08-2003, 02:31 PM   #1 (permalink)
cam swap
What is the difference between the 01 and 02 motors is it just the cam? And if so what cam will go good with my 01 stock heads? I would like to go just above 02 cam. And any idea what kind of RWHP cam swap would make by itself and with headers.
rickeycatzzzzzz is offline   Reply With Quote
Old 12-08-2003, 02:41 PM   #2 (permalink)
cam & valve train are different in 02 and on.
hard to say what you can expect from just a cam swap - depends on the selected cam profile. personally, I wouldn't just install a new cam without new valve train too - but that's just me. Same with headers, it depends on what headers you install.
z62jag is offline   Reply With Quote
Old 12-08-2003, 03:00 PM   #3 (permalink)
Super Moderator
Black_Magic's Avatar
Here is the spec on the CAMS but a mention above the is more then just CAM.
Stock '01 Z06.......204/211 525/525 116
Stock '02-04 Z06..204/218 551/547 117.5
George
Click Here for Black_Magic Home Page
'99 Blk/Blk Vert, 6sp, Magnason S/C, Corsa Indy Pro Tips, M12 Trans, Z06 CAM, FLP Headers, HRE 547's SOLD May/2008
'65 Blue/Blue ZZ4-Dual Quads, TKO 5sp, PS, PB A/C, Tilt, Sidepipes, Torque Thrust II (17*7) (DRIVER)
Black_Magic is offline   Reply With Quote
Old 12-08-2003, 03:47 PM   #4 (permalink)
what else is different besides cam are the heads the same? If so what cam do you suggest besides 02 cam that will work good with my heads?
Old 12-08-2003, 04:02 PM   #5 (permalink)
MikeyB's Avatar
Nothing different of relevance other than cam. Any cam for a LS1 would work good for your 01 LS6. www.thunderracing.com
Old 12-08-2003, 04:04 PM   #6 (permalink)
MikeyB's Avatar
You can only go with shorty headers if you plan to stay emissions legal. With shortys and a good 114 LSA smog legal cam you should get 400 rwhp, maybe a little more.
Old 12-09-2003, 05:53 AM   #7 (permalink)
rickeycatzzzzzz
The 02+ valves are different (sodium filled, I think). Not sure about pushrods & springs but, since the lift was increased, it wouldn't be too suprising to see stronger springs installed. I don't think the 02 heads themselves differ from 01.
What kind of power are you trying to attain? Once you have a stated power goal it will be easier to choose the appropriate mods to attain it. Personally, I wouldn't suggest using the 02 cam & required valve train - too little bang for your buck. Why not discuss your performance (and budget) needs with one of the supporting tuners?
I know this didn't strictly answer your questions but its the best advice I can give at this moment.
3/7 cylinder swap cam MilleniumZ06 C5 Z06 - Pit Road 4 05-23-2006 08:35 AM
Heads and Cam Swap AlanC C5 Z06 - Pit Road 3 06-07-2005 06:25 AM
Where should I go? (Cam Swap) easvette C5 Z06 - Pit Road 5 03-08-2005 12:22 PM
What did pay for your cam swap??? Gman2002Z06 C5 Z06 - Pit Road 16 09-24-2004 05:35 PM
01 after Cam swap 2charmed C5 Z06 - Pit Road 20 10-23-2002 05:23 PM
