Old 12-20-2003, 08:25 AM   #1 (permalink)
Can anyone help diagnose this problem?
Been running the car pretty hard. Definitely screwed something up. Upon light throttle esp. in third and fourth at low rpms I can hear a constant knocking that can also be felt in the shifter. If I press the gas slightly more the noise increases speed with the increased throttle. If I let off the gas the noise goes away and if I stomp it it seems to go away but maybe because the exhaust noise takes over. There is definitely something wrong and I will bring it in, just wondering if anyone has an idea? Thanks
03 Z06 H/C
9.985@138.80
Best 60' 1.41
Old 12-20-2003, 09:07 AM   #2 (permalink)
NYCHASM's Avatar
Are there any DTC's set?
Charlie
Old 12-20-2003, 11:36 AM   #3 (permalink)
Charlie, not sure what you mean.
Old 12-20-2003, 11:40 AM   #4 (permalink)
Send a message via AIM to JDBgn Send a message via Yahoo to JDBgn
Problem codes=DTC's
Get it to a dealer asap before you tear up something else or get stranded.
IMHO
JDBgn is offline   Reply With Quote
Old 12-20-2003, 12:12 PM   #5 (permalink)
No codes were thrown. I was told that this type of problem would likely not throw a code
Old 12-20-2003, 01:11 PM   #6 (permalink)
Send a message via AIM to Birddog-Singer
could be a loose something like the exhaust. Did ya look under the car or around the hood to see where its coming from?? Remember, if you ignore it too long it might go away (not necessarily a good thing)
NCM Member# 23402
I "HAD" a 2003 Z with aTwin-cone intake*Air Bridge*Silicone couplers*acrylic intake plate*Coolant Bypass*CAGS*SLP Headers*X-Pipe*7000 Kel Zenon HID Headlamps * Sequential flashing taillights *XM Radio*
Birddog-Singer is offline   Reply With Quote
Old 12-22-2003, 08:28 AM   #7 (permalink)
nothings loose. Must be in the tranny.
Old 12-22-2003, 08:31 AM   #8 (permalink)
smook's Avatar
Robz,
When you say you were driving hard...
What do you mean by that? Over bad roads, driving fast...??
Bill.
btw You're car is new... 03!! Should be humming'''
What's the mileage?
smook is offline   Reply With Quote
Old 12-22-2003, 08:52 AM   #9 (permalink)
7000miles. Hard drag racing. 10.9x's,11.0x's
Old 12-22-2003, 09:07 AM   #10 (permalink)
Send a message via AIM to NETfiend
Sounds like you definately broke something. You probably broke some teeth off in the diff or broke something in the tranny. It wouldn't be suprising if your running those kinds of numbers on the drag strip. Your best chance of finding exactily where the noise is coming from is to put the thing on a lift and use a stethescope on the various driveline parts while the wheels are spining in the air.
Sand fleas are eating the internet cables!!!
NETfiend is offline   Reply With Quote
Old 12-22-2003, 01:33 PM   #11 (permalink)
Thanks. A stethoscope is something I have.
Tranny guys.... help me diagnose this problem Chirodan C5 Z06 - Pit Road 6 12-23-2006 06:38 PM
How to diagnose a crank/no-start esoteric_path C5 Z06 - Pit Road 1 05-15-2006 08:01 AM
Can you diagnose this strange problem? NOW U Z ME C5 Z06 - Pit Road 5 12-22-2003 05:08 PM
Diagnose this...tapping silvertp C5 Z06 - Pit Road 4 11-26-2003 06:08 AM
ATI Supercharger Question: How to diagnose belt slippage? Cerberus C5 Z06 - Forced Induction & Nitrous 4 10-16-2003 02:08 PM
