Can you diagnose this strange problem?
Occasionally my Z06 will exhibit the following symptoms when fully warmed up:
Depressing the brake:
• fails to light up the brake lights
• turns off the running lights and turns on the fog lamps if they are switched to the ON position
• illuminates the dashboard lights and display, even when car is OFF
Depressing the LOCK button on the key fob triggers the alarm
There are no codes to indicate the source of the problem.
After being off for about an hour and a half everything seems to return to normal function.
Anyone else have this happen? What is the source of the problem and how did you get it fixed?
Nick
Born 9/5/2001... Halltech T1C, 30lb SVO injectors, MAFT, 178 degree thermostat, Vinci fan controller, throttle body bypass, Lowered to bushings, CAGS, Kirban Billet Shifter, Hardbar Shift Knob (lowered), hardwired Valentine One, GM Cargo Net, Andy's Partition and Cargo Hatch Covers, Brake Duct Screens, Hood Seal, Magnetic Oil Plug, Dash & door sill decals, Exhaust Plate, Frame Saver wheels, Rocker Rails, RS Tweeter Mod, Shortie Antenna, PIAA 1100X Fog Lights, PIAA Silicon Wiper Blades, Amber Euro taillights and side markers, Zaino on everthing
352.7 RWHP / 346.2 RWTQ on 3/9/02 (bone stock)
370.4 RWHP / 370.94 RWTQ on 12/7/02 (with intake, temp and tuning mods)
