Old 07-04-2006, 07:27 PM   #1 (permalink)
Castrol 10W/60 TWS Full synthetic - is it ok?
A local Z06 owner told me he rans a full synthetic made by Castrol...10/60 is the weight...does this seem ok? What would the advantages be to run this oil? This is the same sort of oil I used to run on my old M3....??
Thanks....
TAILWAG is offline   Reply With Quote
Old 07-04-2006, 08:23 PM   #2 (permalink)
Are you still running the stock motor?
'03 Z06 447 c.i. N/A Built by ECS
600+ RWHP 600+ RWTQ
The fastest MPH N/A Z06 in the USA! Courtesy of ECS
Antivenom 447 is offline   Reply With Quote
Old 07-04-2006, 08:25 PM   #3 (permalink)
yup...I am in the stock motor with about 37,000 miles...
Old 07-04-2006, 08:33 PM   #4 (permalink)
I would NOT run anything that heavy in a stock motor, i.e. stock crank/bearings w/stock clearances. 10W30 works fine in these motors, street and track (stock bottom end).
Les
Thanks....
[sold] 02 QS Z06 383 c.i.
Old 07-05-2006, 09:22 PM   #5 (permalink)
I agree with Les. The LS6 motor was designed to run with an oil in with a viscosity in the range of 10-12 cST which a 30 weight is at 212F. Even a 50 weight is about 80% higher in viscosity. The only reason I know of to run an oil with that high a viscosity is if your oil temp is really high, say on the order of 300F, where a 60 weights viscosity will be nearer the correct range for the motor.
For my track use, I see oil temps on the order of 250F (I have an oil cooler) and I only run a 10w40. I can't see needing a 10w60 with a stock motor.
FS: Kumho Tires: 1 V710 (315); full set of Victoracers (full tread) wtknght1 Racing 0 02-21-2006 10:55 AM
5w-30 or 10w-30? rpallas C5 Z06 - Pit Road 7 09-30-2003 11:16 AM
FS: Castrol SRF - The ultimate Racing Brak Fluid atoyf Member Sales - Parts & Cars 7 09-23-2003 08:37 AM
Is anyone running Castrol SRF on a daily driver car? Why not? atoyf C5 Z06 - Pit Road 4 06-16-2003 04:34 PM
Castrol SRF Brake Fluid MXRACER The Garage 2 07-10-2002 08:51 AM
