Old 04-20-2008, 06:40 PM   #1 (permalink)
CF Braille Battery Installed
Got the 11.5 lb CF Braille Installed this weekend (see below). Installed pretty easy and looks great. The weight savings will be nice up front.
Thanks Justin G and Andy S for help in ordering the right one....
cf-braille-battery-installed-dsc00364.jpg  cf-braille-battery-installed-dsc00365.jpg
Old 04-21-2008, 09:39 AM   #2 (permalink)
Re: CF Braille Battery Installed
Looks great. Let us know how it holds up over time. I'm thinking about getting one myself.
MY 2003, 733RWHP, 655RWTQ, forged 383, D1SC procharger, Kooks headers, heads/cam, LG coilovers, lots of other stuff
Chris Holmes is offline   Reply With Quote
Old 04-21-2008, 11:51 AM   #3 (permalink)
PA Z06's Avatar
Send a message via AIM to PA Z06
Im curious too
385 rwhp/381 rwtq
Lg Headers, Breathless CAI
Roll bar, Sparco EVO L
02 Silver Z06
PA Z06 is offline   Reply With Quote
Old 04-28-2008, 05:08 PM   #4 (permalink)
USA #1's Avatar
Very nice
Is that a C5 battery hold-down that Braille supplied?
2004 Machine Silver Z - American Racing Headers, Borla Stingers, Elite Engineering Tunnel Plate & Pedals, Black Powdercoated SpeedLines, TPMS, Lowered, Tinted, Blackwing, Hurst Shifter, MGW Pistol Grip, Exhaust Plate, Screens, 180 T-Stat, Power Antenna, Ceramic Pads, Partition, Passport 8500, Raptor Shift Light, Ipod Adaptor, BMW Jack Pucks, CLB, Amsoil Fluids, ECM tune by Charlie @ RPM. Future Mods: Cam & Stereo.
USA #1 is offline   Reply With Quote
Old 04-28-2008, 09:09 PM   #5 (permalink)
Nice.
Old 04-29-2008, 02:47 PM   #6 (permalink)
Thanks for the compliments. Took it for the first drive since the install on Saturday and everything worked fine. Cranked the car over 5 or 6 times just like my Optima Red Top did, battery voltage read high during travel (per DIC), & hold down kit worked fine....all in all, no problems yet !!!
The heavy duty plastic mount kit that I used (in pictures) is sold by Braille, however, per another members recommendation, I purchased the side post adapters and identical mount kit from Autozone for about $10 total....
One thing I should note, is that for mounting the battery on its side, I had to double up (buy an extra set) the thick pink-ish colored rubber washers that go on the J-hooks, so that the wing nuts would still engage the threads on the J-hooks, due to the reduced thickness of the battery & mounting it on its side....
If you do not use doubled-up rubber washers the wing nuts thread all the way down on the single rubber washer past the bottom of the j-hook threads and just spin free and the battery remains a little loose and can slide around some in the battery tray....
Old 04-29-2008, 08:26 PM   #7 (permalink)
Do you drive your Z often? I was told that if you let it sit more than a couple of days your battery will be dead when you try to take the car out. Can you let us know if this is the case? TIA.
Old 04-30-2008, 10:55 AM   #8 (permalink)
I usually only drive my Z a couple days a week and keep the battery hooked up to the tender when Im not driving it, so the battery going dead is really not a possibility, unless it turns out to be a defect.....
That said, Ill try an experiment this week or next week when I dont have to drive it and leave it off the tender for about 4 or 5 days and see if it goes dead.....Ill post the results when I find out what happens
Old 04-30-2008, 08:26 PM   #9 (permalink)
Yeah, I just want to see how it does off the tender. Thanks.
Alex
Old 05-03-2008, 05:01 AM   #10 (permalink)
Alex
Me too. Let us know how it does connected and not driven for a week or so.
99 Factory Race Car
AFR 205's, 220/224 cam, LS6 intake, Callaway Honker, LG Pro long tubes, Borla Stingers, Katech timing chain, Ported oil pump, ATI harmonic balancer, Hurst, Bilstein shocks, Hotchkis sway bars.
Top Speed186 mph on Autobahn A60 near Spangdahlem A.B. Germany 11/7/03
http://community.webshots.com/user/robsc5
RobsC5 is offline   Reply With Quote
Old 05-03-2008, 07:26 PM   #11 (permalink)
Sounds good guys. Ill leave it off the tender starting tomorrow night (Sunday) and see how it holds up till Friday or Saturday of the next week....
Old 05-11-2008, 08:17 PM   #12 (permalink)
Well, I left the car off the battery tender for 5 days (Sunday to Friday) and it started right up, no problems.....Hope this info helps everybody....
Old 05-12-2008, 10:40 AM   #13 (permalink)
Good news. Thanks!
Braille B2015 battery ok for my car? Chris Holmes C5 Z06 - Grandstand 8 03-29-2008 12:23 PM
Braille battery for Z06 screamindman C5 Z06 - Pit Road 9 03-14-2008 02:27 PM
Braille battery on the way! black96ws6 C5 Z06 - Pit Road 10 03-04-2008 10:06 PM
Braille Battery install pic!!! JustinG C5 Z06 - Pit Road 69 02-04-2008 07:52 AM
Braille Battery issues stellablu C5 Z06 - Grandstand 6 02-12-2006 08:43 AM
