Old 12-25-2002, 01:39 PM   #1 (permalink)
Change Brake Fluid
Can anyone tell me how to change Brake Fluid as in "Brake Fluid Change for Dummies"? I think I know how to bleed brakes altought I have never done it. But I don't think you can just drain the system dry and add new fluid. Also, what brake fluid would you recommend for Auto-X and tack events that is still suitable for street?
LtMash1A is offline   Reply With Quote
Old 12-25-2002, 01:59 PM   #2 (permalink)
Here a post by gmBlack that should help
Here is the procedure from the GM manual, It includes bleeding the master cylinder whick you should not have to do.
Note the order of the Bleed: RR, LF, LR and RF.
Hydraulic Brake System Bleeding Manual
Notice
When adding fluid to the brake master cylinder reservoir, use only Delco Supreme 11® (GM P/N 12377967) or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container. The use of any type of fluid other than the recommended type of brake fluid, may cause contamination which could result in damage to the internal rubber seals and/or rubber linings of hydraulic brake system components.
Notice
Avoid spilling brake fluid onto painted surfaces, electrical connections, wiring, or cables. Brake fluid will damage painted surfaces and cause corrosion to electrical components. If any brake fluid comes in contact with painted surfaces, immediately flush the area with water. If any brake fluid comes in contact with electrical connections, wiring, or cables, use a clean shop cloth to wipe away the fluid.
Place a clean shop cloth beneath the brake master cylinder to prevent brake fluid spills.
With the ignition OFF and the brakes cool, apply the brakes 3-5 times, or until the brake pedal becomes firm, in order to deplete the brake booster power reserve.
If you have performed a brake master cylinder bench bleeding on this vehicle, or if you disconnected the brake pipes from the master cylinder, you must perform the following steps:
Ensure that the brake master cylinder reservoir is full to the maximum-fill level. If necessary, add Delco Supreme 11® (GM P/N 12377967) or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container. Clean the outside of the reservoir on and around the reservoir cap prior to removing the cap and diaphragm, if cap removal is necessary.
With the rear brake pipe installed securely to the master cylinder, loosen and separate the front brake pipe from the front port of the brake master cylinder.
Allow a small amount of brake fluid to gravity bleed from the open port of the master cylinder.
Reconnect the brake pipe to the master cylinder port and tighten securely.
Have an assistant slowly depress the brake pedal fully and maintain steady pressure on the pedal.
Loosen the same brake pipe to purge air from the open port of the master cylinder.
Tighten the brake pipe, then have the assistant slowly release the brake pedal.
Wait 15 seconds, then repeat steps 3.3-3.7 until all air is purged from the same port of the master cylinder.
With the front brake pipe installed securely to the master cylinder, (after all air has been purged from the front port of the master cylinder), loosen and separate the rear brake pipe from the master cylinder, then repeat steps 3.3-3.8.
After completing the final master cylinder port bleeding procedure, ensure that both of the brake pipe-to-master cylinder fittings are properly tightened.
Fill the brake master cylinder reservoir with Delco Supreme 11® (GM P/N 12377967) or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container. Ensure that the brake master cylinder reservoir remains at least half-full during this bleeding procedure. Add fluid as needed to maintain the proper level. Clean the outside of the reservoir on and around the reservoir cap prior to removing the cap and diaphragm, when cap removal is necessary.
Install a proper box-end wrench onto the RIGHT REAR wheel hydraulic circuit bleeder valve, then install a transparent hose over the end of the bleeder valve.
Submerge the open end of the transparent hose into a transparent container partially filled with Delco Supreme 11® (GM P/N 12377967) or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container.
Have an assistant slowly depress the brake pedal fully and maintain pedal position.
Loosen the bleeder valve to purge air from the wheel hydraulic circuit.
Tighten the bleeder valve, then have the assistant slowly release the brake pedal.
Wait 15 seconds, then repeat steps 7-9 until all air is purged from the same wheel hydraulic circuit.
With the right rear wheel hydraulic circuit bleeder valve tightened securely, (after all air has been purged from the right rear hydraulic circuit), install a proper box-end wrench onto the LEFT FRONT wheel hydraulic circuit bleeder valve, install a transparent hose over the end of the bleeder valve, then repeat steps 6-10.
With the left front wheel hydraulic circuit bleeder valve tightened securely, (after all air has been purged from the left front hydraulic circuit), install a proper box-end wrench onto the LEFT REAR wheel hydraulic circuit bleeder valve, install a transparent hose over the end of the bleeder valve, then repeat steps 6-10.
With the left rear wheel hydraulic circuit bleeder valve tightened securely, (after all air has been purged from the left rear hydraulic circuit), install a proper box-end wrench onto the RIGHT FRONT wheel hydraulic circuit bleeder valve, install a transparent hose over the end of the bleeder valve, then repeat steps 6-10.
After completing the final wheel hydraulic circuit bleeding procedure, ensure that each of the 4 wheel hydraulic circuit bleeder valves are properly tightened.
Fill the brake master cylinder reservoir to the maximum-fill level with Delco Supreme 11® (GM P/N 12377967) or equivalent DOT-3 brake fluid from a clean, sealed brake fluid container.
Slowly depress and release the brake pedal. Observe the feel of the brake pedal.
If the brake pedal feels spongy, repeat the bleeding procedure again. If the brake pedal still feels spongy after repeating the bleeding procedure, perform the following steps:
Inspect the brake system for external leaks. Refer to Brake System External Leak Inspection .
Pressure bleed the hydraulic brake system in order to purge any air that may still be trapped in the system.
Turn the ignition key ON, with the engine OFF. Check to see if the brake system warning lamp remains illuminated.
If the brake system warning lamp remains illuminated, DO NOT allow the vehicle to be driven until it is diagnosed and repaired. Refer to Symptoms - Hydraulic Brakes .
For type of Fluid check this site,seems like some of the people that Auto-X use this.
http://www.alfredteves.com/
vette1 is offline   Reply With Quote
Old 12-25-2002, 03:11 PM   #3 (permalink)
So from this I gather you are bleeding the old fluid out at the wheels and adding new fluid from the top. How do you know all the old fluid is out? The fluid from the wheels starts to look clean? Can you bleed the old fluid out from the wheel furthrest from the Master Cyl., then bleed the other wheels to check for air?
Old 12-26-2002, 08:01 AM   #4 (permalink)
When gmblack3 and I bled our brakes we found that the first wheel we bled took a fair number of pumps before we started getting clean fluid, we pumped probably 15-20 more times at that wheel before moving to the next. Make sure to keep the reservoir filled.
After the first wheel there was much less old fluid to bleed from the rest.
We used ATE super blue fluid so it was easy to see when the new fluid got to the wheel being bled, but you should still be able to tell the difference between the old fluid and the new fluid.
Chris
woosch is offline   Reply With Quote
brake fluid change question Ness70 C5 Z06 - Pit Road 15 05-04-2006 05:43 PM
When to change Brake Fluid? SGT. PYLE C5 Z06 - Pit Road 8 08-20-2005 03:32 AM
Brake fluid change? pflynn C5 Z06 - Pit Road 24 01-30-2005 08:58 AM
Should I change my brake fluid? Cobra4B C5 Z06 - Pit Road 17 11-24-2003 02:18 PM
paging c4c5 for help on brake fluid change Miguel Ruggeri C5 Z06 - Pit Road 9 04-29-2002 11:56 AM
