View Poll Results: Can the tire rotation direction be changed?
I HAVE changed rotation and it was okay 3 27.27%
I HAVE changed rotation and it was NOT okay 0 0%
I THINK changing rotation is okay 2 18.18%
I THINK changing rotation is NOT okay 6 54.55%
Voters: 11. You may not vote on this poll
Old 05-01-2002, 02:42 PM   #1 (permalink)
Changing tire rotation direction.
After two open track events, my right front is starting to look pretty bad along the outside. I want to swap the fronts (left to right). There was a thread a while back with no conclusive information as to wether this is okay.
I know the Kumho Victoracer can be run in any position and any direction so long as the "side facing outwards" is such. Since the F1 Supercar tire is non-directional, I would hope the same is true for it.
jknight is offline   Reply With Quote
Old 05-01-2002, 03:24 PM   #2 (permalink)
Re: Changing tire rotation direction.
Everything I have read about the tire says its assymetrical, but not directional. So it doesn't matter which side of the car its on.
* Mike Garfias
Old 05-01-2002, 03:55 PM   #3 (permalink)
I believe the tires do need to be on the same position they came on. Although the tire is assymetrical the pattern on the inside is diffrent than the outside for a reason. It will effect handling at least on wet surfaces.
02ZO6 is offline   Reply With Quote
Old 05-01-2002, 04:03 PM   #4 (permalink)
02ZO6,
Not trying to argue but your statement is incorrect. As long as you leave the tires on the wheels and just swap the wheels with tires attached the pattern will stay as intended. Just visualize it, I did with my Z06 Die cast model on my desk.
As far as should you do it, I don't know. However I seen no harm in it as the tires are NOT directional.
Just my .02
TRZ06 is offline   Reply With Quote
Old 05-01-2002, 04:42 PM   #5 (permalink)
You can do it, but I don't think it is a good idea. I have seen lots of problems( tire, pulling , ply separation,etc) over the past 25 years( since radial tires became the norm) but maybe tires have gotten better, and I am still living in the " dark ages"?
My 16th Corvette. 2001 ZO6. Lowered 2 in,04 shocks, HRE 547s, Mich Pilots,Eradispeeds, TPIS,Borla ,Cartek 2X, Blackwing/Power Duct,LS1 Edit,Kirban, DRM Roll Bar,Sparco, Specter Werkes rear facia and C5-R Hdlts, ACI splitter.
515 HP/471 TQ
CSX1965@comcast.net
Baron is offline   Reply With Quote
Old 05-01-2002, 04:53 PM   #6 (permalink)
TRZ,
You are correct. I thought it was a tire only swap. Switching the rim and tire would not help even out wear unless the road course was left or right turn only like roundy round racing.
Old 05-01-2002, 07:53 PM   #7 (permalink)
Not sure on this one If I had to guess, I'd say stay away from doing it especailly if your going to be on a road course
Jason
01' Quicksilver Z06
Jayzvette is offline   Reply With Quote
Old 05-02-2002, 09:22 AM   #8 (permalink)
Z06 Maniac!!
Lawdogg's Avatar
Running at BIR, the outside of the left front wears fast due to a 135 mph banked sweeper followed by a 125 mph flat sweeper both to the right. If I didn't swap the location of the fronts after 20 laps or so, the left front would cord when the right front was still in great shape. I've switched them many times and run those sweepers and the 160 mph straight leading into those sweepers without any tire problems.
'07 Z06 Lemans Blue
Old 05-02-2002, 09:26 AM   #9 (permalink)
Thanks Ripped.Z06. I got the notice of your reply post in my inbox at almost the exact same time as the following. FWIW
From: consumer_relations@goodyear.com on 05/02/2002 11:20 AM
Sent by: Goodyear Tire & Rubber Company
Consumer Relations 739
1144 East Market Street
Akron, OH 44316
Voice #: (800) 321-2136
Fax #: (330) 796-3753
Hi Jeff:
Thank you for contacting our web site, we appreciate your kind words referencing the performance of the Eagle F1 Supercar tire.
This tire is of a asymmetrical tread design, meaning the tire must be mounted with the correct side facing outward to receive the full benefit of the tire and the tread design. The Supercar tire is not a unidirectional design and can be moved from side to side, as long as the proper mounting procedures have been followed.
Dave Johnson
Customer Relations
Old 05-05-2002, 07:03 PM   #10 (permalink)
I stand corrected. Thanks for the info. Baron
Old 05-06-2002, 06:13 AM   #11 (permalink)
Swapped them this weekend for the Track Guys event at Mid America Motorplex. No problems. Thanks again for the replies.
C6Z Tire Rotation WhosUrDaddy C6 Z06 - Pit Road 25 07-27-2006 02:19 PM
Tire direction for SC's 01Z06Wicked1 C5 Z06 - Pit Road 8 02-24-2005 08:38 AM
Z06 Tire Rotation? COUTO1981 C5 Z06 - Pit Road 15 12-29-2004 05:48 PM
Stock Z06 tires don't have a single "direction of rotation" do they? Z06-Nomad C5 Z06 - Grandstand 23 01-31-2003 08:43 AM
Tire rotation gbjerke C5 Z06 - Pit Road 24 04-26-2002 02:31 AM
