Old 12-22-2004, 06:16 AM   #1 (permalink)
check gauge + 11 gal. = full tank ?
thought I was out of gas but only 11 gallons later I'm spilling fuel, what went wrong?
seat rocks,column lock,trunk release,exhaust jingle,fuel gauge,what else did I forget? I want to bring it in and have them all done at once and don't want to forget anything.
redline water wetter,chevron techron,magnetic drain plug,andy's partition. 354.7 stock dyno
hugoagogo is online now   Reply With Quote
Old 12-22-2004, 06:46 AM   #2 (permalink)
itsaz's Avatar
427 TT
itsaz is online now   Reply With Quote
Old 12-22-2004, 02:31 PM   #3 (permalink)
The upper portion of the seat rocking is intentional according to the owners video. I didnt' get the column lock recall done, as its not a problem for me. The trunk release, thats funny....I took mine in to get fixed, 30 minutes and 40 bucks later it was "fixed". Aforementioned "fix" lasted a week, so I took it back...they then said "well all the C5s trunks don't open very far" needless to say I demanded my money back for "fixing" something that "wasn't broken" and got it back. Which reminds me I need to cash that check! I too have the fuel gauge issue, presently I do what some of the other forum members suggested, I reset one of my trip odometers as a sort of backup fuel measurement device!
jzmopar1969 is offline   Reply With Quote
Old 01-13-2005, 05:30 AM   #4 (permalink)
Send a message via AIM to Vettitude
Didn't quite get all of the fuel tank issue, but if you are running an empty tank and check gauges, you are probably having what I just experienced last week. Turned out to be bad gas, after some reading, found that if the sulphur content in the gas mix is too high, it will mess with the fuel tank sensor. I filled it up again at another station, and 2 days later when I fired up the car, everything went back to normal, and has stayed that way so far. I drove it around the first time, to burn down the tank a bit so I could put a measureable amount back in it to cure the problem.
J
01' Blk/Blk, Vararam, WCC Power Duct, SuperMaxx Headers, B&B Bullets, ZEX Nitrous 100 Shot, Hurst Shifter, Bilstein Shocks, Lowered 2", Z06 Motorsports w/Kumho 18"s, MSD Wires, Partition, Lloyd Mats.
Vettitude is offline   Reply With Quote
Old 01-13-2005, 06:53 AM   #5 (permalink)
On the fuel sensor issue - a lot of us use Red Line or Techron fuel system cleaner regularly. Personally, I use a few ounces avery tank. My gage is now regular. It must be fiber for the fuel system.
turbolisa is offline   Reply With Quote
Old 01-21-2005, 02:27 PM   #6 (permalink)
IVOZ06's Avatar
Send a message via Yahoo to IVOZ06
Fuel problem comes from high sulfur content in fuel.
Chevron fuel is the best. Chevron tech fuel system cleaner is about 10 bucks but it does the job!!!
I do not suffer from insanity, I enjoy every minute of it!
CLICK FOR MY PICS
LIFE IS TOO SHORT, HAVE FUN, NO REGRETS
IVOZ06 is offline   Reply With Quote
Old 01-22-2005, 01:48 PM   #7 (permalink)
UVETTYA's Avatar
I use Chevron exclusively and add a can of Techron fuel system cleaner after each oil change. I still had issues with my guage and they changed the right module a few weeks ago. The service writer said it's not just Corvettes that have this problem.
Steve
Black '04 Z06
UVETTYA is offline   Reply With Quote
keep gas tank 1/2 full? (not z specific) gresch C5 Z06 - Pit Road 21 03-31-2005 11:22 AM
i leave my tank 1/2 full don527 C5 Z06 - Pit Road 0 03-31-2005 10:59 AM
How many Miles do you get with a full tank??? Z06 Rocket C5 Z06 - Pit Road 13 03-30-2005 04:33 AM
can't get a full tank gresch C5 Z06 - Grandstand 16 06-21-2004 08:04 PM
Less rumble with full tank??? Red Kelly C5 Z06 - Pit Road 0 04-21-2002 12:27 PM
