Checked 2002 Z06 Fuel Trim Cells
Car not moving:
Open Loop Idle : 20
Closed Loop Idle, No A/C : 19
Closed Loop Idle, A/C : 18
Deceleration : 21
WOT : 22
Cells 0 - 17 are used while driving. They are also used when revving in neutral. The cell used is based on engine load. Low loads get the lower cells, higher loads get the higher cells. You normally get Cells 0 & 1 when the car is moving and the engine is idling. This can include neutral or in gear.
