Old 04-02-2006, 09:42 PM   #1 (permalink)
Clutch fluid change questions.
I was giving the Z06 it’s first under hood inspection of the year when I saw a “new” place to put fluids it. It turns out to be the clutch fluid reservoir, and it looks like the fluid could stand a change. I understand that bleeding the clutch is a PITA if you don’t have the bleeder installed.
Is it reasonable to suck out what is in the reservoir with a Turkey Baster and repeat this procedure routinely? Will any DOT3 fluid get the job done or is something else recommended?
Thanks again in advance.
Old 04-03-2006, 05:11 AM   #2 (permalink)
That's exactly what I did to mine. After each fill, pump the clutch pedal several times to get the fluid to circulate. It took several "baster dips" to get the fluid clean, but it was well worth it. High quality DOT 3 brake fluid is fine.
Bill
BillsZ06 is offline   Reply With Quote
Old 04-03-2006, 07:37 AM   #3 (permalink)
DennyM's Avatar
If you're not tracking the car, DOT 3 is best.
DOT 4 has a higher wet/dry boiling point, but is more hydroscopic.
Don't add DOT 4 to a current DOT 3 fill. Have to drain and purge first.
Old 04-03-2006, 08:01 AM   #4 (permalink)
Good question
jjwvette is offline   Reply With Quote
Old 04-03-2006, 09:35 AM   #5 (permalink)
UVETTYA's Avatar
I use the turkey baster trick every oil change. 28K miles now and no issues with the clutch. When this clutch goes I'll put in a bleeder.
Steve
Black '04 Z06
UVETTYA is offline   Reply With Quote
Old 04-03-2006, 03:37 PM   #6 (permalink)
My car does see the track - road course only. I guess I will have to break out the shop manual tonight and see what's involved with a drain/fill.
Old 04-03-2006, 05:37 PM   #7 (permalink)
You'll be fine doing what you said you were doing!
Old 04-03-2006, 09:07 PM   #8 (permalink)
Bleeding is a major PITA as the bleed port is on top of the housing. To get to it requires removing the exhaust center section and the heat shield which has about half a million bolts holding it in... or maybe 36 but it seems like half a million...
Short of that, I think the turkey baster method is your best bet.
Old 05-03-2006, 01:07 PM   #9 (permalink)
DennyM's Avatar
My Bad ... confusing Brake fluid and Clutch fluid concerns???
My post above was about need to purge ABS when going to DOT 4 fluid in BRAKE system.
NOW ... since Brake fluid can be used as clutch fluid, my question:
Can I "turkey baster" out old clutch fluid and add DOT 4 brake fluid and thru several repeat sucks and fills refresh my fluid from mostly DOT 3 equivalent clutch fluid to nearly all DOT 4 brake fluid fill as clutch fluid. (I've got enouh Motul 600 RBF around to do this) .
Old 05-03-2006, 01:19 PM   #10 (permalink)
dwjZ06's Avatar
My post above was about need to purge ABS when going to DOT 6 fluid in BRAKE system.
Denny,
I did this not to long ago. I replaced the stock fluid with DOT 4 ATE Super type 200 fluid Amber instead of blue so it will not stain anything blue. Anyway the turkey baster method and drive it around some and bleed it again. After several times it seems better color wise and have not had any issues so far. Don
SIG by GR8 WHITE
Clutch fluid change (pics) hailskins666 C6 Z06 - Pit Road 30 04-14-2008 10:54 PM
Clutch fluid change question, plus shock install follies! saki302 C5 Z06 - Pit Road 2 05-09-2006 04:03 AM
How to Change Clutch Fluid? coopz06 Racing 7 06-20-2003 09:25 AM
How to Change Clutch Fluid? coopz06 C5 Z06 - Grandstand 3 06-19-2003 01:18 PM
Brake & Clutch Partial Fluid Change pmontelo C5 Z06 - Pit Road 16 07-12-2002 02:05 PM
