Old 03-27-2008, 04:05 PM   #46 (permalink)
Flex182's Avatar
Re: Clutch replacement / install post mortem
Well tom, May hats off to you...thats an amazing time..I guess after 3 times your pretty proficient at it..I hope to be as well. I just wish The c5 was designed to replace things alot easier..I imagine the c6 is probably similar isnt it ?
R.D.M.
Flex182 is offline   Reply With Quote
Old 03-27-2008, 04:21 PM   #47 (permalink)
The clutch replacement is pretty much the same in the C5/C6..a lot more work than doing the same on a F body car.. Tom is "the man" I remember when he did his in the Vette Museum parking lot a few years back... he amazed a bunch of folks with that on jack stands thrash....if you ever partake in the hot rod magazine power tour you will see all kinds of cars being thrashed in various ways in parking lots..you gotta do what ya gotta do when your on the road..
Steve Tillman
45 Years Of Corvette Experience
Y2K NBM 6MT HP?\TQ?
It's stock they all sound like that
Steve Tillman is offline   Reply With Quote
Old 05-08-2008, 03:22 PM   #48 (permalink)
KansasCityZ06's Avatar
So the axles just pop out with a hard yank? We got to this point lastnight and we wondered if the boot needed removed. But all the DIY pics show the boot still in-tact. It seems to make a "bottoming out" noise and stops at a point. Just yank harder?
Steve
2001 Z06, IForged Daytonas (20x11, 19x9.5), Michelin PS2s, Upgraded Tranny w/Textralia clutch/Billet Flywheel, RPM 3.90 Diff., Simple Bolt-ons
KansasCityZ06 is offline   Reply With Quote
Old 06-23-2008, 11:18 AM   #49 (permalink)
panzer's Avatar
I updated the thread and relinked the pictures that were boken during the database corruption. I also added a few that are new.
1985 BMW K100 m/c
Old 06-23-2008, 11:36 PM   #50 (permalink)
AZZ061's Avatar
wow you guys make it easy for me to justify why i paid someone to do it
AZZ061 is offline   Reply With Quote
Old 06-24-2008, 04:31 AM   #51 (permalink)
panzer's Avatar
But you don't get the satisfaction of having done it yourself and the intimate knowledge of your car. It only gets interesting when you put it together and you have parts left over...
Old 06-30-2008, 07:07 AM   #52 (permalink)
Just finished my clutch install on jack stand and ramps in my garage. Take your time. I used the pilot bearing that came with the spec clutch. The face is flat not tapered like the gm version. I spent 8 hrs trying to get everything lined up. Was within half an inch, but would not slide together flush. Yanked the PP and clutch back out pulled the pilot bearing out and replaced with one from gm. Took off the shifter base from torque tube assebmly and everything went in perfect. Rent the blind bearing puller set and the bearing installer from autozone.
95formula is offline   Reply With Quote
Old 06-30-2008, 08:56 AM   #53 (permalink)
panzer's Avatar
My hat is off to you 95formula. Having done this on a two post lift I know the pain the butt you had in doing it on jack stands and a floor creeper. salute
Need advice on clutch replacement panzer C5 Z06 - Pit Road 50 11-13-2006 11:04 AM
First clutch replacement FlosyZ06 C5 Z06 - Pit Road 20 05-18-2005 08:14 AM
2k for a stock clutch replacement? MrKool C5 Z06 - Grandstand 60 08-06-2004 10:52 AM
Trans Am Clutch Replacement capn37 The Garage 4 07-15-2004 08:10 AM
Post clutch install squeak mystery solved- something to look out for ZO6Cam C5 Z06 - Pit Road 2 03-07-2004 01:52 PM
