Clutch and Tranny replaced
Finally got my car back today! Took it in Nov 29 with tranny stuck in 4th gear. Clutch had been sticking to the floor. I appreciate the advise I got here in dealing with problem. I asked dealer again today if there was anything on the Tech Line or any kind of bulletin out about this problem. NO was the answer. I asked if the "fix" included any upgraded parts. He was rather vague about this but implied that there were upgrades. Here was there discription of the condition and then the fix.
Tech Comm: Tranny kicks out of 3rd stuck in 4th disassemble tranny found sycro blocker broken input shaft main shaft had rough pitted area and discolored priced out parts exceeded new tranny replaced tranny assm replaced clutch master cyl and slave cyl due to master cyl faulty slave cyl leaking
repair transmission assembly, replace
line 5 clutch pedal sticks at floor
cause: out of round
tech comment: clutch act cyl stuck to floor bore in cyl out of round replaced clutch actuator cyl
Clutch and transmission appear to be working perfectly. Hopefully what ever "new" parts they installed will prevent these problems in the future. While mine was in, there was another 02 with clutch problems being worked on.
I was concerned about the mods on my car possibly voiding my warranty but total charges were $0.
