cold air intake & cut cats out do you need to tune AFR with one of these devices--->
For 2001 Z06:
From what I've read in the archives the rear O2 sensors actually give the computer air/fuel readings so the O2 simulators won't be affective if you cut out the cats? And if you add a cold air intake it will cause too much air flow causing a lean condition? So to correct both of these problems you have to use on of these devices below to get the most from your mods and have the correct air/fuel ratio? Which one will work the best and easiest for the Z06?
1. Ramchargers MAF translator $189
2. Halltech MAF signal box - the AFR $275
3. Split Second ARC1 $264
4. Split Second ARC2 $550
Out of the software and air/fuel ratio meter below which is the best to get the most accurate dial in settings for the air/fuel calibrators above?
1. Autotap software $279
2. Ease Enhanced software $345
3. Split Second ARM1 $139 is the meter
