Old 07-13-2003, 01:09 PM   #1 (permalink)
column lock help???
i keep getting pull key wait ten seconds, service column lock, on my dtc, what should i do , if i bring it to the dealer how do they usually fix this if it isnt locked at the time i bring it there, also i have my pcm reprogrammed think they will tell if its been reprogrammed?? what usually needs to be replace with this column lock problem??? is it the bcm, the lock cylinder or the steering column relay??
alzo6 is offline   Reply With Quote
Old 07-13-2003, 01:17 PM   #2 (permalink)
Super Moderator
Black_Magic's Avatar
If your column is NOT lock but you are getting the message...Disconnect the battery, wait 10 minutes, reconnect....Should fix ---------- It did mine a couple of times
George
Click Here for Black_Magic Home Page
'99 Blk/Blk Vert, 6sp, Magnason S/C, Corsa Indy Pro Tips, M12 Trans, Z06 CAM, FLP Headers, HRE 547's SOLD May/2008
'65 Blue/Blue ZZ4-Dual Quads, TKO 5sp, PS, PB A/C, Tilt, Sidepipes, Torque Thrust II (17*7) (DRIVER)
Black_Magic is offline   Reply With Quote
Column lock again..... Wht01Z06 C5 Z06 - Pit Road 1 06-16-2006 06:50 AM
column lock again Dr.Bigg C5 Z06 - Grandstand 26 06-10-2006 11:06 AM
I'm in column lock! thezs06 C5 Z06 - Pit Road 3 07-13-2003 12:42 PM
What is column lock? VettTheRipper C5 Z06 - Pit Road 1 01-03-2002 09:00 AM
Column Lock Bypass Kit...prevent 'lock-up' on your Z06 RG Vendor Sales - C5 20 02-02-2001 08:05 AM
