Old 06-09-2006, 06:21 AM   #1 (permalink)
Corsa Ti exhaust Q's- leaky? (and Callaway honker done!)
Hi guys!
I finally got my car back from the dealer on Wednesday- it turns out instead of just changing the one leaky diff seal, they basically rebuiilt the diff- I see 7 (!) seals on my work order, sheesh. I wiped it down totally clean tonight, so we'll see if it leaks again.
I finally got around to installing my Corsa Ti exhaust, and my Callaway honker.
The honker installs like a dream- everything just falls into place, and fits better than factory, IMO. Very well done, and fully worth it. I had to buy a pop riveter to join the air box with the shroud.
The Corsa Ti went on with a lot more work. Removing the stock exhaust without cutting it was a beyotch! I couldn't get my jack to lift high enough, so I resorted to using wood to space it up- yuck..
When I started it up, the Corsa sounds awesome (street mufflers). Like how it should sound from the factory!
The popping/gurgling seems to be gone- the true H pipe probably fixed it I assume.
Here's the minor problem- I notice it isn't sealing well where the H-pipe meets the first muffler, and at one of the cat-to-H-pipe joints.
It's not a terrible leak (most of the exhaust goes out the back), but you can feel it with a bare finger.
Would it hurt anything to run around with a minor leak for awhile? It doesn't seem to affect the noise level at all.
And is there a good non-permanent fix for the leaks? I saw a Corsa Ti done with a bunch of silicone sealant, but once dry, I know that stuff will be near impossible to remove, never mind actually trying to disassemble it...
Thanks!
-Dave
2003 TR Z06, CAGS elim, Column lock bypass, A&A rails/ skate rollers, Hurst shifter, MOMO knob/boot, Corsa Ti, Callaway Honker, Uber pricey AMW catch tank
saki302 is offline   Reply With Quote
Old 06-09-2006, 06:29 AM   #2 (permalink)
Did you use new gasgets?
jjwvette is offline   Reply With Quote
Old 06-09-2006, 06:52 AM   #3 (permalink)
Cobra4B's Avatar
Pics!
Old 06-09-2006, 02:56 PM   #4 (permalink)
Gaskets?!?! The Corsa Ti simply slips together and uses flat clamps which are tightened with a single nut. I've seen guys who put silicone all over the joint, then all over the underside of the clamp too- presumably to seal it all up!
Just wondering if there's another way, or if it's better to leave it as is.
I'll get some pics up in a day or two- I haven;t pulled it out of the garage yet
-Dave
Old 06-09-2006, 04:27 PM   #5 (permalink)
I took a few pics for you guys- it's hard to see much with the exhaust since I don't have a lift to get under there- I took two phoots of the tips for you.
-Dave
Old 06-09-2006, 07:48 PM   #6 (permalink)
Speedratchet's Avatar
I don't know how much room you have, but I have had real good luck with these band clamps. They seal great if you use a impact gun on them. Most auto stores have them now.
Visit me at: Speedratchet
Old 06-09-2006, 09:17 PM   #7 (permalink)
Intake and exhaust look good.
Alex
Old 06-10-2006, 01:14 AM   #8 (permalink)
Hmm.. I'll keep ane ye out for those clamps. The clamps they give to grip pretty well, I think it migth be an issue with it being an old exhasut. Some of the connections look a little warbled from going on and off. Kinda stuck with a used one now if you want to go Corsa Ti...
I took it for a spin- it really sounds nice- great angry sounds above 3000 rpms!
-Dave
Old 06-12-2006, 11:38 AM   #9 (permalink)
You could always put a little sealant on the joints after it's installed, that way you'll be able to get it apart again.
I had the same system (Corsa Ti Street) and the joints all leaked a little, nothing too bad. No issues with performance or setting codes, etc.
'02 EB/MR Z
80% Track, 20% Driver, 100% Z
Thumbs Up for Callaway "Honker" dougatl C6 Z06 - Pit Road 30 07-12-2006 01:46 PM
Callaway Honker and the Halltech Tunnel Port??? MidnightHour C5 Z06 - Pit Road 7 05-05-2006 01:23 PM
leaky exhaust gasket, now my car sounds normal. mannygmt2 C5 Z06 - Pit Road 0 06-09-2005 02:23 PM
Corsa X pipe, with Corsa Ti exhaust. Zed C5 Z06 - Pit Road 4 08-03-2002 12:01 PM
Help me decide between Corsa Pace or Corsa Z Ti exhaust TRZ06 C5 Z06 - Pit Road 4 06-12-2002 06:20 AM
