Old 10-05-2004, 08:22 PM   #1 (permalink)
Dead Z
Key fobs don't work. Car won't crank. Codes reveal only that _NO_ module can be communicated with.
PCM - No Comm
RFA, BCM, etc
they're all dead
the battery has good voltage, any ideas?
* Mike Garfias
Old 10-05-2004, 08:54 PM   #2 (permalink)
Cave Man's Avatar
Send a message via MSN to Cave Man
Sounds to me like you're trying to start the wrong car.
Just kidding obviously, I have no clue.
Marcus Aurelius
Cave Man is offline   Reply With Quote
Old 10-05-2004, 10:09 PM   #3 (permalink)
Hammer?????
BPP Long Tubes, Spec 2 Clutch, Drilled and Slotted, Hardened Output Shaft, BPP Edit, Corsa X-Pipe, No Cats, Indy Corsa's Pro's, BPP Ram Air, Vortex Power Duct, BPP Ported T.B., TB Coolant Bypass, Kirban Custom Shifter, Momo Cobra Knob, Tints, Lowered
Z-Ya Later is offline   Reply With Quote
Old 10-05-2004, 10:16 PM   #4 (permalink)
Take the key and cycle(lock, unlock, etc) it in the driver's door a time or two then get in and try to start it again. I works on older Vettes, perhaps it will work for you.
Good luck,
Brad
EDIT- ERR...this is CobraKilla not SS2Z06
2002 QS z06, 408 (callies crank, ls4 oil pump, etc.)A&A YSI-trim kit, 8-rib, custom dual pump setup (by sabe oliver), ETP LS-7 heads, custom cam, LS-7 intake, SDPC/kooks 1 7/8-2" longtubes, 96lb injectors, APS 3" exhaust, exedy twin disk and speed density tune by Nick at Newtech performance. 806rwhp, 671 rwtq
2008 AO z06, ported intake and tb, vararam, corsa exhaust. tuned by nick at newtech 486rwhp 453 tq
ss2z06 is offline   Reply With Quote
Old 10-06-2004, 07:28 AM   #5 (permalink)
Pulled the neg batt cable for about 20 mins... That "fixed" it. I wonder if something on the communications bus crashed. The lights on the radio/climate control were stuck on before I pulled the cable.
Old 10-06-2004, 07:41 AM   #6 (permalink)
panzer's Avatar
You have an 01 also so make sure you have good connections and good ground from the cables around the battery and to the frame. There is a ground bolt near the pass side hood hinge near the fuses. Since the battery is good I suspect corrosion on some main cable. The PCM and other computer modules have to have good current to work right.
1985 BMW K100 m/c
Old 10-06-2004, 08:10 AM   #7 (permalink)
Cave Man's Avatar
I'm glad you got it started. I would schedule a diagnostic just in case.
Lets beat a dead horse....but a very specific dead horse FLYNAVY30 C5 Z06 - Pit Road 38 02-17-2006 03:43 PM
Dead Z 03VETT C5 Z06 - Pit Road 13 12-14-2003 04:45 PM
The Z is dead for now TwistnArm4AZ C5 Z06 - Pit Road 10 07-29-2003 12:17 PM
They Are Dead ! azzkiknZO6 The Garage 11 07-22-2003 09:52 PM
Dead Battery - I Mean DEAD cpa1racer C5 Z06 - Grandstand 11 04-13-2003 04:12 PM
