Old 11-10-2005, 06:14 PM   #1 (permalink)
Dealer Oil Change... or me?
Should I do it or have the dealer do it? This is the forth oil change.
Also the brakes pads are looking slim for the first time. What do you guys recommend? I plan to do a big brake kit in the spring along with bigger rims so nothing to expensive on the brakes. Some nice pads and maybe brakes lines if they are worth it.
Chrisrokc is offline   Reply With Quote
Old 11-10-2005, 06:43 PM   #2 (permalink)
PerforminNorman's Avatar
Ummm I think I'm missing something here. You are asking US if YOU should change your own oil or have someone else do it?
Assuming I understand the question correctly. If you like to do this kind of work, or if you don't trust others to do it right, I'd say do it yourself. Otherwise have the dealership do it.
Come to the Z06 Fest!
Performin' Norman
Old 11-10-2005, 07:31 PM   #3 (permalink)
Send a message via AIM to 3Pedal_Z06 Send a message via MSN to 3Pedal_Z06 Send a message via Yahoo to 3Pedal_Z06
If you can do it on your own, I that is what I would recommend. The best way to know it was done right is to do it your self.
Kevin
SIG by GR8 WHITE
HP 354 TQ 348
3Pedal_Z06 is offline   Reply With Quote
Old 11-10-2005, 07:43 PM   #4 (permalink)
Lol! Basicly yea.
I changed the oil among many other things on my 00 Trans Am for over 3 years so I can do this I guess. Any ideas on the best way to get under my car? It is lowered all the way on stock bolts.
Oh also, it has been awhile since I have been under a LSx car. Do I need it to be level to get all the oil to drain out?
Old 11-10-2005, 07:43 PM   #5 (permalink)
DennyM's Avatar
What 3pedal said ^^^^^.
I like to look around under there ... like for leaks, loose things, etc.
For Crisrokc ... best check the "lifting for oil change" long running thread.
Lifting for Oil Change
One way ...to drive onto a 2x10 board, then lift from side with jack ... or from front with jack and 2x6 x 20-24" board laid across the font member, then rear member ...
Old 11-10-2005, 09:25 PM   #6 (permalink)
Do it yourself... You will take the time to let it drain properly, you won't overtighten or strip the oil pan bolt... You can pre-fill the filter for instant lube on start-up. You can clean your hands before you get in the car. You won't dent ot scratch it and you get to go for a road test! You also save some $$$...
I enjoy working on my cars... I sit all week at a desk.. so I look forward to doing real work!
C5~Missle is offline   Reply With Quote
Old 11-13-2005, 04:56 AM   #7 (permalink)
It's easy. Jacks on the front and then lift the rear a tad higher than the front. This drains all the oil to the front of the pan, where the drain plug is.
Resist is offline   Reply With Quote
Old 11-13-2005, 06:57 PM   #8 (permalink)
If you're going to do this yourself you may have to drive the car onto something that'll elevate the car about an inch or two higher in the front. I need to do that to be able to roll a jack under it.
Obviously if you have a lift or some other contraptions then you won't have this issue...
03 TR/Blk Z06, Borla Stingers, K&N AirCharger
szlaszlo is offline   Reply With Quote
Oil change % digital readout accurate or should i change at 3000? briann510 C5 Z06 - Pit Road 17 08-28-2005 08:25 AM
Dealer dumps vette off lift during an oil change! corvettes Dealer Experience 18 07-01-2004 12:34 PM
Oil & Oil Filter Change Intervals gaijin C5 Z06 - Pit Road 0 03-29-2003 08:31 PM
Do you change your oil pan with every oil change? (I do) Big D C5 Z06 - Grandstand 9 10-07-2002 01:53 PM
Local Chevy Dealer Hacks Up Brand New 2001 Camaro During Routine Oil Change Z06Scott The Garage 1 04-16-2001 10:33 PM
