Old 07-05-2005, 07:21 AM   #1 (permalink)
Detonation when shifting at high RPM.
My Z detonates breifly but loudly when shifting at high RPMS.
When I hit the hext higher gear and mash the gas, I get a pretty lound but quick detonation that is very audible. It goes away in under a second or less, even when I stay on the gas.
I am using 93 octane fuel, that has 10% methanol from the refinery( Gulf) . It does it with other gas without alky in it too.
Does anyone else have this issue? Detonation that loud is bad news, as you all know....
Innovator is offline   Reply With Quote
Old 07-05-2005, 07:36 AM   #2 (permalink)
How many miles on your car? You might be a candidate for a De-carbonization Procedure
http://www.corvetteforum.com/techtip...=212&TopicID=1
Old 07-05-2005, 08:02 AM   #3 (permalink)
Thank you for the tip. I now have 5500 miles on it, but it did it at 2200 when I got it.
I'm not sure if it's the gas, but since I've used a few types, I'm leaning against the gas. Vararam? Maybe. Although, I've never seen an air cleaner make so much of a difference, as to lean out the engine.
BTW, a product called Sea Foam is the best decarbonizer I've used to date. We use it at my shop on cars that run 87 octane that have a detonation problem, and it makes a huge difference after the treatment.
We suck it through the PCV hose slowly at first, and then towards the end of the bottle, we let it go through at full blast until the engine stalls. Then we let it sit for as long as possible (overnight if possible). Then we give it a (Polish Tune-up), which involves some WOT in a few gears
Old 07-05-2005, 08:17 AM   #4 (permalink)
Send a message via AIM to JDBgn Send a message via Yahoo to JDBgn
Sounds like you are hitting the rev limiter which cuts off the engine at 6500 RPM.
Shift just below that and you will get the best performance as far as speed goes.
You should not have carbon build up, that was with leaded fuel and before fuel injectors.
MHO
JDBgn is offline   Reply With Quote
Old 07-05-2005, 08:23 AM   #5 (permalink)
Not the rev limiter. It's detonation for sure.
Old 07-05-2005, 08:42 AM   #6 (permalink)
any mods or tuning done to your car....possibly need to back off a bit on timing?
C5 CU is offline   Reply With Quote
Old 07-05-2005, 08:53 AM   #7 (permalink)
Basanni H pipe and Vararam 2B.
Old 07-05-2005, 09:52 AM   #8 (permalink)
Send a message via AIM to niphilli
Could be throttle tip-in (part throttle tuning). Most tuners only mess with WOT tuning but tip in has to be adjusted sometimes. I can imagine having these issues with a car lightly modded like yours though. Is the car under warrenty? If so take off the Vararam and take her in. Actually take off the vara ram first and see if it goes away.
I like Cars
niphilli is offline   Reply With Quote
Old 07-05-2005, 10:41 AM   #9 (permalink)
Experienced same thing on dyno...
We changed the plugs and wires and it went away.
Good luck
NA 346 CID
483 rwhp
440 rwtq
OhOneZOhSiXXX is offline   Reply With Quote
Old 07-05-2005, 02:11 PM   #10 (permalink)
Good luck
I have the new AC Iridium plugs installed. The wires though? With 5500 on the odo? What would that do?
Old 07-06-2005, 04:50 AM   #11 (permalink)
mine had less than 4k...both plugs and wires...granted they were not iridium (which is what we switched to) but detonated nevertheless.
maybe changing the wires will have no effect...i dont know...we changed both simultaneously.
its a cheap suggestion. thats all.
worst case: it doesnt work, and you have a spare set of plugs and wires (which you will probably need anyway, especially if you have/are considering getting headers)
good luck
Tranny not wanting to go into gear at high RPM's. riggs C5 Z06 - Pit Road 11 09-11-2006 02:35 PM
Missing 5th gear at high rpm ledsled87 C5 Z06 - Pit Road 9 08-15-2006 09:05 PM
High-Effort Shifting (normal?) pvknight C5 Z06 - Pit Road 8 03-14-2006 07:01 PM
High RPM and AC JLH-Z06 C5 Z06 - Pit Road 12 07-05-2002 10:45 AM
When racing, at what rpm are you shifting at? don527 C5 Z06 - Pit Road 11 01-18-2001 04:03 AM
