Originally Posted by vetteracer
Came up twice in one day last summer. That was months ago and it never returned. I was told by dealer that sometimes on startup things get out of sync and not to worry unless it comes on through several startups in a row. Both times I saw it I just turned the car off and restarted and it went away.
Bingo!
On most situations where this comes up on the DIC it's due to the steering wheel being in a turn, either left or right, and you back up when first turning the key and starting the car..
Point being the system has to know where "striaght" is as the steering position sensor is a reference point for the active handling. Just as you have discovered, shut the car off with the wheels straight and the warning is bye-bye.
