Does an aluminum flywheel = lower 1/4 times or faster acceleration? - Z06Vette.com - Corvette Z06 Forum
post #1 of 9 (permalink) Old 06-02-2004, 05:47 AM Thread Starter
People always say the car revs quicker... is this meaning that the car is accelerating faster?
Current: 2001 Quicksilver Z06 - TT2/ST2 racecar
Old: 2001 Screamin' Yellow Targa Z06 - SOLD
Cobra4B is offline
post #2 of 9 (permalink) Old 06-02-2004, 05:51 AM
i think of it as getting to optimum power band quicker...
C5 CU is offline
post #3 of 9 (permalink) Old 06-02-2004, 06:11 AM
Send a message via AIM to NETfiend
It probably will make getting good 1/4 mile times much more difficult. You need a lot more finesse to keep an engine that revs faster from breaking traction.
Sand fleas are eating the internet cables!!!
NETfiend is offline
post #4 of 9 (permalink) Old 06-02-2004, 10:07 AM
faster car .
speedpup is offline
post #5 of 9 (permalink) Old 06-02-2004, 10:12 AM
RocketSled's Avatar
It should. The lightweight setups like Fidenza's reduce the weight of the Clutch/Pressure Plate/Flywheel by nearly 50% (something like 25 pounds). Besides the obvious simple benefit of the overall reduction in weight, the reduced mass means the rotational intertia of the assembly is also much lower. That rotational intertia looks like a much larger load to the engine that the weight alone would imply. And it takes HP to accelerate that flywheel mass as the engine speeds up. Reducing the rotating mass makes more HP available to the rest of the drive line, and that allows the rest of the driveline to accelerate faster. Since the car is attached to the driveline, it accelerates faster, too.
Because of inertia, rotating masses actually have an effect disproportionate to their actual weight. Reducing rotating mass is always a good way to improve acceleration. It pays back more than just the LBS you take out of the system.
Note that wheels also matter. They rotate, usually weigh as much or more than the clutch/flywheel assembly, have a larger diameter, and of course there are 4 of them. Interia varies with the square of radius, so the same weight hurts more in a road wheel than a flywheel. While I have no science to back it up, the rule-of-thumb I've heard is that every LB of rotating wheel weight is the equivalent of 4-5 LBs of dead weight.
You don't actually get more HP from the engine, of course, but it ends up looking that way to a dyno (and Seat Of The Pants). Since the inertia only consumes power when it's being accelerated (I'm totally ignoring friction here), the top speed of the car is unaffected (but you get there quicker).
C6!
RocketSled is offline
post #6 of 9 (permalink) Old 06-02-2004, 11:12 AM
And, because you are accelerating quicker in lower gears, the effect is much more noticable in 1st and 2nd, versus 3-6.
-Jake
JakeL is offline
post #7 of 9 (permalink) Old 06-02-2004, 11:37 AM Thread Starter
Thanks everyone... I'm really leaning toward a LUK stage II when I replace my clutch. $800ish but hopefully I won't have to do a clutch again even w/ h/c.
Cobra4B is offline
post #8 of 9 (permalink) Old 06-02-2004, 12:11 PM
Very well said RocketSled!
X
xsiveone is offline
post #9 of 9 (permalink) Old 06-02-2004, 01:36 PM
have you found the Z06 stocker to be insufficient with 400+ rw?
I was thinking of moving up to a Z06 stocker on my car-of-all-trades, (will be ~425-450rw) but perhaps a touch more than that is in order?
-Jake
JakeL is offline
How will I like an aluminum flywheel? BillY2KFRC C5 Z06 - Pit Road 30 06-03-2004 07:46 PM
Aluminum Flywheel G Stamatakos C5 Z06 - Pit Road 4 10-27-2003 06:05 PM
Aluminum Flywheel jtw_z06 C5 Z06 - Pit Road 5 02-15-2003 08:01 PM
Aluminum Flywheel? urpow C5 Z06 - Pit Road 2 01-01-2003 11:46 AM
Aluminum flywheel 02C5Z06 C5 Z06 - Pit Road 18 08-22-2002 05:07 AM
