Driver's side rearview mirror - Help! - Z06Vette.com - Corvette Z06 Forum
post #1 of 20 (permalink) Old 11-24-2012, 09:39 AM Thread Starter
Zealot06's Avatar
While backing out of my narrow garage this morning, the dirver's side mirror housing caught on the very edge of my garage door frame. No visible damage to the housing, but the mirror is loose in the housing and has cracked. The power control still moves the mirror but is doesn't have very good control since the mirror has evidently become dislodged from the actuator.
I did a search on the forum regarding broken outside mirrors but didn't find anyone who has had a similar experience. Knowing my luck I'm probably breaking new ground here with a bonehead stunt like this
Can anyone offer any advice on what it may take to fix my mirror? Is this possibly a DIY job?
Meanwhile, I'll try to hold back the tears!
Thanks for the help.
Zealot06 is offline
post #2 of 20 (permalink) Old 11-24-2012, 10:10 AM
Re: Driver's side rearview mirror - Help!
On my 2500HD, you have to replace the whole mirror assembly/housing. But it's relatively easy by removing 3 screws/bolts and unplugging one connector and reversing for the install. I would look for a used one or a new one from a parts store--just don't use a dealer unless you have lots and lots of extra money. Hopefully, someone will have a better answer for you.
fcar is offline
post #3 of 20 (permalink) Old 11-24-2012, 11:16 AM
On the other forum they said that mirror can be replaced. Chk--sideview mirror repair--posts were made in 2002. Hope this helps
fcar is offline
post #4 of 20 (permalink) Old 11-25-2012, 05:21 AM Thread Starter
Zealot06's Avatar
Thanks fcar! I've found a couple of posts that will probably help. When I get a new mirror I'll do a post showing my repair procedure.
Zealot06 is offline
post #5 of 20 (permalink) Old 12-07-2012, 01:09 PM
Okay, seems I have same issue. Drivers side mirror (light sensitive) has started to fail in that the light sensing material sandwiched in the glass is seeping downward leaving only about 2/3's of the mirror usable. I have asked my dealer to look at replacing the glass BUT, they recommend replacing the whole housing as they have found that the mirror glass has 3 plastic tabs on the back and can/will break on installation. A new complete housing is $500-$740 depending on where you can get it. The glass only is about $100. I am pissed I'm stuck in this conundrum. I have even asked a different body shop and same answer. Really, glass breaks or fails and I have to spend close to a thousand bucks(housing, shipping, paint) before I even install it? Anybody got any good news?
Thanks in advance.
2003 Z06 TR (Bone Stock)375rwhp/365tq
GClausen is offline
post #6 of 20 (permalink) Old 12-07-2012, 06:01 PM
Originally Posted by GClausen View Post
Okay, seems I have same issue. ...
Thanks in advance.
The good news is that if you had a Toyota Yaris, Ford Festiva, or Chevy Aveo the mirrors would be much less to replace.
Dog
meldog21 is offline
post #7 of 20 (permalink) Old 12-08-2012, 01:02 AM
Thanks in advance.
Sorry to say, welcome to the world of GMomics. Freaking parts are ridiculous to say the least.
Keep your eye out (on the other forum) for a car being parted out. They are being listed all the time. Good Luck!
jub jub is offline
post #8 of 20 (permalink) Old 12-08-2012, 07:16 AM
YumaZ06's Avatar
Location: Yuma, Az. ?????? Z06 Fest IV, V, VII, VIII, IX, X, XII & Winterfest 1,2,3 & 4
Check flea bay for C5 mirrors or glass.
2004 MS/BLK
YumaZ06 is offline
post #9 of 20 (permalink) Old 12-30-2012, 09:29 AM Thread Starter
Zealot06's Avatar
:bump:
OK, I have done quite a bit of searching for a replacement mirror for my Z06. Since my car has the "super deluxe" version (memory, heated and electrochomic light-sensing), there will be mucho dollars involved. I have not yet seen a used assembly that has all 3 features.
While searching, I found a company that offers a replacement mirror that has a turn signal built into the mirror glass (you guys probably know who this is). I am intrigued by the extra margin of safety this mod would add. I could replace both my outside mirrors for the turn signal mod and actually save money by not going for the cost of replacing the original mirror.
So, what say you--safety or originality?
Zealot06 is offline
post #10 of 20 (permalink) Old 12-31-2012, 09:39 AM
PerforminNorman's Avatar
I did the exact same thing to my 02 back in the day. I just bought a new one and replaced it.
LS15 Power! LS2 + LS6 + LS7 = LS15.
PerforminNorman is offline
post #11 of 20 (permalink) Old 12-31-2012, 11:12 AM Thread Starter
Zealot06's Avatar
Norman, you mean you just replaced the damaged mirror, or went for the turn signal mod?
Zealot06 is offline
post #12 of 20 (permalink) Old 12-31-2012, 11:36 AM
ZOHBABY's Avatar
I thought I had a problem in my driver side rearview mirror.
But then he realized, I drive a Z06!
'03 Black Z06
Corvette - Driven to be driven
ZOHBABY is offline
post #13 of 20 (permalink) Old 01-13-2013, 12:54 PM Thread Starter
Zealot06's Avatar
After a long and difficult search, I found a whole driver's side mirror and housing assembly from a sports car salvage dealer here in Ohio. Here's the finished product
The removal and replacement of the mirror assembly was not all that difficult. I had to repair 2 door panel pins using JB Kwik Weld, and that worked great. I suppose I could have purchased the replacement auto-dimming, heated mirror glass and a new actuator motor (which was broken, too), and then attempted a replacement of those components in my existing housing, but I was concerned about breaking the mirror during removal/replacement.
Feels good to have her back together and working properly, but it was an expensive mistake! Oh well.....
Zealot06 is offline
post #14 of 20 (permalink) Old 01-13-2013, 01:39 PM
YumaZ06's Avatar
Sh$t happens, but you did a great job on fixing it. Ahh..JB Weld, a mechanics friend.
2004 MS/BLK
YumaZ06 is offline
post #15 of 20 (permalink) Old 01-13-2013, 01:43 PM
Congrats on getting it "fixed"! Looks just like new.
fcar is offline
Rearview Mirror Compass Fuse? Racin Jason C6 Z06 - Grandstand 2 08-31-2011 11:49 AM
Rearview Mirror fix? navyasw02 C6 Z06 - Grandstand 2 09-02-2007 12:09 PM
Rearview mirror mount for radar detector... Sixxcat1 C5 Z06 - Grandstand 1 02-13-2006 08:55 PM
Hardwire radar detector into rearview mirror rsdonzi C5 Z06 - Pit Road 1 12-23-2003 04:30 PM
how to remove rearview mirror? robiferretti C5 Z06 - Pit Road 5 05-29-2003 06:52 PM
