Old 08-26-2005, 10:53 AM   #1 (permalink)
% drivline loss
I've never understood the idea of using a particular % (15, for example) to "convert" between crank hp and rwhp.
A 400hp car would dyno at 340, using a 15% loss. That means its drivetrain sapped 60hp.
If I mod the car to 500hp, it would dyno at 425hp(using 15%). That means the SAME drivetrain is now sapping 75hp.
At 600hp...........driveline loss is now 90hp!....etc...etc
Does this make sense to everyone? I'd think that a fixed loss per car would make more sense.
Let's discuss!
petegtsv10 is offline   Reply With Quote
Old 08-26-2005, 11:28 AM   #2 (permalink)
Well, I'm not sure if this is the right forum, mods can move this
if they deem fit of course.
It actually IS a percent.
The losses from power measured at the crank to power meas.
at the wheels are effectively a combo of two things:
1) Frictional losses
2) Inertial losses
The magnitude of the Inertial losses are generally orders of
magnitude greater.
So we can consider "losses" to mean "inertial losses".
If and when you are talking about a dyno that measures the
horsepower under acceleration, this matters.
Double the power means double the torque means double the
acceleration, this means double the losses thru inertia.
So the inertial losses are proportional to the power output
in a given system. It's a percentage.
Jim
Jim Conforti is offline   Reply With Quote
Old 08-26-2005, 11:39 AM   #3 (permalink)
Cave Man's Avatar
Send a message via MSN to Cave Man
I know that in the ventilation industry you have to figure a certain cfm% loss everytime you turn air. Its pretty much a mechanical function and the % is not affected by the volume. I'm not sure how torque/hp works.
I found this thread . It may help. But most of it is over my head.
Marcus Aurelius
Cave Man is offline   Reply With Quote
Old 08-26-2005, 11:58 AM   #4 (permalink)
13% is the loss that I measured, ASSUMING that my engine produces 405 HP at the flywheel.
LoneRegister is offline   Reply With Quote
Old 08-26-2005, 12:21 PM   #5 (permalink)
For large helical gearboxes we figure 2% per mesh if mounted on anti-friction bearings. It's based on average sliding friction between the gear teeth. Your mileage may vary.
Old 08-26-2005, 12:53 PM   #6 (permalink)
Someone once stated here that Cooksey at the Plant in Bowling Green said it's actually 13% for driveline loss for our six speed manual trannys.
01ZEE06 is offline   Reply With Quote
Old 08-26-2005, 03:27 PM   #7 (permalink)
RocketSled's Avatar
Frictional resistance is proportional to the force with which the two moving objects press together. This means that changes in frictional losses in the driveline are proportional to the changes in the force being translated through the driveline. This means that when you make more HP, you lose more HP. It's one of the cruelest twists of physics.
Kind of like death and taxes. There's no escaping it.
C6!
GM Loss BOBSZ06 C6 Z06 - Pit Road 50 03-26-2005 01:39 AM
Perhaps my loss is your gain? GroundFighter Employment 11 01-22-2003 10:03 PM
loss of hp lMr Z06l C5 Z06 - Pit Road 15 12-21-2002 04:07 PM
Loss of Power charliet C5 Z06 - Pit Road 11 12-09-2002 07:50 PM
14% LOSS It Is quikdoc C5 Z06 - Pit Road 30 05-20-2002 05:29 PM
