Originally Posted by ZO6 NTHEWIND
It says right on DRM's website that 'will not work with the pfadt swaybars'
So if your shop 'modified' them so that they will work and pfadt says they will work then it looks like problem solved.
Later,
here is the ad on the DRM website...
Front Brake Ducts for C5 Corvettes (T-1 Legal)
Instead of blowing air aimlessly around the wheel well, these brake ducts finish where GM left off. Air is blown directly into the hub/rotor area to dramatically reduce rotor temperature. Works with up to 10" wide 18" tall front rims. These are now standard equipment on our C500/RSR.
We recommend using these in combination with our Stainless Steel Braided Brake Lines and Stainless Steel Pistons for the ultimate in repetitive and high speed stopping performance on stock GM calipers.
Last summer while we were developing these ducts, our C500/RSR test car with just the factory cooling would repeatedly burn and damage the piston seals on our 6-piston AP calipers after 4-6 hours of very hard track driving at Road America. After installation of these ducts, we have yet to see any failures of the piston seals after 20 hours of high speed testing!
Kit includes left and right ducts with high temp hose and clamp. All hardware included with instructions. 1 hour installation time.
Please note, these will not fit select ride Corvettes
DRM Brake ducts 15-100 $199.95
nowhere did it indicate that it will not work with pfadt sway bars.
Aaron did indicate that based on ride height, clearance, and positioning, that it was possible that they would hit.
Since adjustable ride height was a feature of his coil-overs, as well as adjustability of his sway bars, this was a possibility.
I had the car lowered, a setting of 8 set for the coil overs and sway bars, and had an aggressive street/track alignment done.
Just passing on to other Z06 owners that this could possibly happen if you combine these products and settings.
I am very impressed and happy with the performance of the Pfadt Coil-Overs and Sport Sway bars, and glad to have input from Aaron himself.
the solution in the end from John Page of 21st Century Muscle Cars was to heat the DRM ducts to reshape them so that they would clear the Pfadt sway bars and still connect with the LG spindle ducts...
yes problem solved, but not as advertised by DRM,and more than just 1 hour of installation time, so just letting anyone else know that if they want to try this great setup, this might be necessary based on ride height and alignment.
Thanks again Aaron for your input.
