DRM Front brake cooling ducts
Z06 tracksters-
For those who can run the DRM cooling ducts in their class, do these work and if so are they worth it? Is there a better way?
I've looked at pics of the ducts and they appear too short to effectively direct the air to the brakes.
Also, thinking out loud, if they do work as is or retrofitted, any issues with directing the air picked up from so close to the ground with all the track marbles, rocks and other neat stuff which proliferates the "less than perfect lines." Seems as though the aftermarket wire mesh covers for the brake intake would actually add value.
Are these for real or just for bragging rights?
