Dyno # Uncorrected vs SAE - Z06Vette.com - Corvette Z06 Forum
post #1 of 23 (permalink) Old 08-08-2007, 09:07 PM Thread Starter
What is the difference between SAE & Uncorrected numbers on a Dyno?? What do both numbers mean? What if any is the difference with STD vs. the previous figures?
Thanks!
04 Torch Red Z06, TTi X Stage Twin Turbos, Patriot stage 2 ,062 Vinici cam, DTE Brace, LS7 Clutch, Rear Partition,V-1,Corsa Indy Cat=Back, T-Ported,3M Clear Bra,Chrome Z06 Wheels,Wilwood 6 Piston with GT Rotors.
jz06man is offline
post #2 of 23 (permalink) Old 08-08-2007, 09:18 PM
RC45's Avatar
Location: Houston, Z06 Fest Non-Attendee I II III IV V VI VII VIII IX X :(
Re: Dyno # Uncorrected vs SAE
Uncorrected or actual numbers are the power numbers as measured at the atmospheric conditions of the time of the test. (more power on a cool day, leess on a hot humid day)
Corrected numbers are the "as tested" actual numbers with an accepted correction factor applied to normalise the results to those that would be measured at a known standard temperature and pressure.
As an example, here is my cars dyno showing SAE corrected numbers - the actual measured numbers on that hot humid day were less - but the number was multiplied by a correction factor of 1.04 to show the power that the engine would have produced had the conditions been the same as those of the "SAE Standard" temperature and pressure.
This allows for tests on different days at different altitudes and temperatures to be somewhat accurately compared.
I would expect the same engine to produce significantly more power on a cool crisp 59* winter day - so for that dyno, the correction factor would be more like 0.8 or less.
STD is simply another "standard" that will have a normalized correction factor applied.
MTI/Katech/Englandgreen CamZilla LS7 Z07, Kooks, Fast Intake, Stock Ti SAE 570rwhp & 530ft-lb N/A @ Englandgreen, Houston
RC45 is offline
post #3 of 23 (permalink) Old 08-12-2007, 08:42 AM
FRC Tom's Avatar
I have WinPep 7 on my laptop which is the software that is used for a DynoJet.
I have taken the same dyno sheet and have converted from sae to uncorrected to standard for your viewing pleasure.
This is a base run of a 2006 Z06 with just over 500 miles on it.
Conditions were:
84.77 degrees
24.99 in-hg
70% humidity.
Correction factor is zero of course uncorrected.
1.03 CF in SAE
1.05 CF in STD.
ID:	1501   Click image for larger version
ID:	1502   Click image for larger version
It is what it is
Still the Best
FRC Tom is offline
post #4 of 23 (permalink) Old 08-23-2007, 08:36 PM
So lets say your SAE numbers are higher than your uncorrected(actual) numbers, could you still rightfully say the SAE numbers are legitimate power of the car?
2002 Quicksilver Corvette z06
B&M Precision Sport Shifter
Halltech Stinger SSM
A&A Tune 379/368 SAE
Magnaflow X Pipe(post dyno tune)
DitchTehFish is offline
post #5 of 23 (permalink) Old 08-23-2007, 09:10 PM
MikesZ06's Avatar
Thanks!
How to get 505rwhp with bolt ons
See post #34
Vette Magazine article
1/4 mile pass
MikesZ06 is offline
post #6 of 23 (permalink) Old 08-24-2007, 12:40 AM
RC45's Avatar
Yes - because they are the normalised numbers.
RC45 is offline
post #7 of 23 (permalink) Old 08-24-2007, 02:08 PM
RocketSled's Avatar
You could say "this is the power it car makes under these environmental conditions".
To make valid comparisons of successive performance tests (like when you're tuning the car) or tests on different cars (like at a Dyno event), where the environment can be different from one run to the next (as stated, engines make more power in cold/dry than they do in hot/wet), you need to normalize the measurements to they're all mathematically adjusted to the same baseline condition. "Corrected" = "Normalized".
C6!
RocketSled is offline
post #8 of 23 (permalink) Old 08-24-2007, 03:52 PM
Not really, although that is the goal, the problem is the dynos weather station is not that accurate and can be fooled, intentionally or otherwise.
The purpose of SAE correction as others have stated is to "normalize" the environmental conditions. The older SAE J607 standard assumes the engine is being run where the environmental conditions are 60F, 0% humidity with a barometric pressure of 29.92 in-Hg. Whereas the newer SAE J1349 standard is 77F with 0% humidity and a barometric pressure of 29.234 in-Hg.
That means if you were to place your car in an environmentally controlled room having those conditions, the SAE corrected H.P. is what it should make. Therefore, you can take two cars for example; anywhere in the world at any time and compare their SAE corrected numbers as though they were being tested in that same room at the same time under the same conditions. "Same conditions" meaning using the same SAE standards: either the J607 or J1349. You can't compare apples to oranges.
Again, it's a great idea in theory but in actual practice, it is not that accurate a lot of the time for a variety of reasons.
I should add that the LS7 for example was tested using the SAE J1349 standard. So, if the current weather conditions are better or worse than that the engines performance will be either > or < than 505 H.P..
Given that, is the engine a 480 H.P. engine or a 530 H.P. engine? Again, it depends on the actual conditions. The 505 H.P. was achieved under those specific conditions and since all LS7 engines are virtually identical, they all test the same, under the same identical conditions.
No Doubt is offline
post #9 of 23 (permalink) Old 08-24-2007, 10:52 PM
FRC Tom's Avatar
No Doubt:
You are blowing me away this week with the knowledge you have on this and a couple of other subjects.
Thank you....................
It is what it is
Still the Best
FRC Tom is offline
post #10 of 23 (permalink) Old 08-25-2007, 07:14 AM
Z06 WinterFest Coordinator
Kens06's Avatar
Location: Gilbert, AZ Z06 Fest II,III,IV,V WinterFest 1,2,3
Send a message via AIM to Kens06
OK, here is my tilt to this corrected vs uncorrected session!
In March, I did ten runs at a local dyno with FRCTom trying to tune my car with worn out overstressed injectors. OAT ~ 65*
The red line is the safest we did that day.
The blue line is last weekend.
No changes to the car, just 110* temp and more humidity than usual for AZ.
You can't tell me there is any correction factor that will predict this kind of change!!
http://www.z06vette.com/gallery/index.php?n=501
I did it because I wanted to see real numbers of what I'm putting down in triple digit weather conditiions out here!!
I almost like the hot weather more, because the RII's stick like glue and you can be really aggressive with the GO pedal!!
I almost need to use the 6 point belts to go on a beer run, but that's just me!!
My .02
Ken
Kens06 is offline
post #11 of 23 (permalink) Old 08-25-2007, 07:20 AM
FRC Tom's Avatar
Did you ever get injectors for that pig you ole drunk?????????????
It is what it is
Still the Best
FRC Tom is offline
post #12 of 23 (permalink) Old 08-25-2007, 07:30 AM
Kens06's Avatar
Nope!!
I never drive it. Why you have a set of 42's laying around i can buy??
Ken
PS sorry for the temp hi-jack!!
Kens06 is offline
post #13 of 23 (permalink) Old 08-25-2007, 08:08 AM
FRC Tom's Avatar
Originally Posted by Kens06 View Post
Nope!!
Ken
If you ain't drivin it then why bother, just start working on winter fest 2, we will get er done then.
It is what it is
Still the Best
FRC Tom is offline
post #14 of 23 (permalink) Old 08-27-2007, 03:15 PM
FRC Tom's Avatar
My .02
Ken
Just looked at the sheet Ken.
I am wondering why it has gone pig rich, triple dig temps will not cause that big of a change in the afr. I had trouble getting enough fuel and now you have too much.
It is what it is
Still the Best
FRC Tom is offline
post #15 of 23 (permalink) Old 08-27-2007, 04:14 PM
Kens06's Avatar
I don't know Tom.
Maybe they had the sniffer in the wrong pipe.
They always try to stick it in the outside pipe and those go thru the muffler on PRT's. You have to use the inside pipes which are straight thru!!
Plus this is Casey's old car so it's probably haunted by the MTI gremlin!!
Ken
Kens06 is offline
Metric or SAE bmac C5 Z06 - Pit Road 3 12-23-2003 08:58 PM
My Z06 only has 48.7 HP (SAE) !!! erix C5 Z06 - Grandstand 23 08-15-2002 01:29 AM
Uncorrected #'s???????/ Roger Ramjet, others? ZO6LS6 C5 Z06 - Pit Road 27 03-05-2002 09:52 AM
Any high elevation uncorrected dyno results? beggar Racing 4 12-18-2001 07:05 PM
STD to SAE Conversion Dyno#s ????? FRC Tom C5 Z06 - Pit Road 2 09-09-2001 12:30 PM
